Patio Roof Supported By 4x4 Posts - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By Mrbuilder
  • 1 Post By House Designer
  • 1 Post By Oso954
Old 02-20-2020, 01:16 AM   #1
Rewards Points: 20
Patio roof supported by 4x4 posts
Our home has a 12x12 patio/porch in the backyard. The porch is attached to the home on one side. There are two 4x4 posts on the side attached to the home/roof close to the walls and there are 3 4x4s on the other side. I have read somewhere that 4x4s might not be enough in some cases.
Can somebody please help me understand whether I need to get these replaced with a 4x6 or 6x6 posts. This has become a constant worry for me.
Suresh.Chowta is offline   Reply With Quote
Old 02-20-2020, 01:45 AM   #2
Rewards Points: 4,824
Re: Patio roof supported by 4x4 posts
Where are you? What is the typical snowfall in your area?
stick\shift is offline   Reply With Quote
Old 02-20-2020, 03:52 AM   #3
Rewards Points: 20
Thank you for your reply.
We are in the bay area (Fremont).
Old 02-20-2020, 07:01 AM   #4
" I Can Fix It "
Mrbuilder's Avatar
Rewards Points: 434
Hello Suresh.Chowta:
It will help us greatly when we give our OPINIONS, if you could take a few pics of your issue to help us better understand. Look just under the posts in Additional Options, click on manage attachments to upload pics. We can help better if we see it. Usually 4x4 columns will be sufficient if the spacing is correct, height is sufficient, and snow load is light, and it isn't
living space. Hope we can help.
And Welcome.
Nealtw likes this.
just sayin
" It's ok if you're not sure, find someone who is"
Mrbuilder is offline   Reply With Quote
Old 02-20-2020, 10:16 AM   #5
Rewards Points: 78
Suresh-I live a few cities away (Alamo) have seen many 4x4 used as post, all seems to be functioning fine. When I build my cover patio (20'x20') with heavy tile roof I used 6x6 through out. For your case going to Home Depot and get Simpson strong ties with structure screws would do the trick, assuming there are no rots.
phentium3 is offline   Reply With Quote
Old 02-20-2020, 10:20 AM   #6
House Designer's Avatar
Rewards Points: 236
For reference,
An 8' tall 4x4 column is rated for 6092 lb. design load.
A 9' tall 4x4 column is rated for 4,956 lb. design load.
I am assuming treated wood- Spruce/Pine/Fir Grade 1.
Two of these posts at the end of a 12' x 12' roof would easily support a Cleveland snow load.
Nealtw likes this.
House Designer is offline   Reply With Quote
Old 02-20-2020, 10:48 AM   #7
retired framer
Rewards Points: 15,762
If you want or need it to be more code compliant, nail a 2x4 to one side and a 2x6 to another and you will have a 5 x 5 1/2"
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Nealtw is offline   Reply With Quote
Old 02-20-2020, 01:32 PM   #8
Oso954's Avatar
Rewards Points: 1,910
What is the source or reason for your worry ?
As the others have pointed out, 4x4 are the traditional and will support the structure on a normal day.
If your concern is seismic, I’d suggest getting an architect or engineer to design any upgrades.
For everyone’s info, the Hayward fault runs right thru the city of Fremont. It is listed as being capable of a 7.5 earthquake. Some people fear a major quake on it, more than the San Andreas Fault.
Nealtw likes this.
Oso954 is online now   Reply With Quote
Old 03-11-2020, 04:59 PM   #9
Rewards Points: 20
Originally Posted by House Designer View Post
For reference,
Thank you House_Designer.
Sorry for the delay in reply. I was not well during the past two weeks.
Old 03-11-2020, 05:03 PM   #10
Rewards Points: 20
And Welcome.
Thank you MrBuilder.
Attached a couple of pictures.
Sorry for the delay as I was not well for a few days.
Patio roof supported by 4x4 posts-img_20200308_131208.jpg   Patio roof supported by 4x4 posts-img_20200308_131140.jpg   Patio roof supported by 4x4 posts-img_20200308_131130.jpg
Old 03-11-2020, 05:05 PM   #11
Rewards Points: 20
Thank you Oso954.
I was worried a bit, because, I got the posts replaced by somebody who did not have a license and wanted to make sure the kids are safe playing in the patio.
Attached some pictures for clarification.
Tags
patio , pillars , porch , posts , pressure treated
