Patio Handrail - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-07-2009, 01:33 AM   #1
liscenced electrician
Rewards Points: 540
patio handrail
I have a house I'm trying to old person proof. The back door goes to a patio made with brick pavers. I want to add a step and was thinking of building it out of the same material. What steps should I take so its built to last? I want to grout in between so there are no brick edges to trip on. Then I want to add a handrail. Are these custom fabricated? How would I secure it to the ground. I was thinking of removing a few bricks digging a hole and pouring concrete
Thanks in advance -jimmy
jimmy21 is offline   Reply With Quote
Old 07-07-2009, 11:59 AM   #2
Rewards Points: 540
http://www.pacificpavingstone.com/im...pavers12sm.jpg
Here is a picture of the same kind of pavers. They are dry set. Would I need to pull them up and put concrete under them to build a second layer that is mortared together on top?
slumped patio fix ?? houser Building & Construction 5 03-18-2010 06:25 AM
Need Patio Advice - Pictures Included kyassassin Landscaping & Lawn Care 45 05-14-2009 01:41 PM
New cememt patio stained by wet leaves Bhoward Landscaping & Lawn Care 7 12-03-2008 11:35 AM
Cement Patio Deteriorating..? DeepDish Building & Construction 6 05-09-2007 10:03 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 08:11 AM
