Patching Smooth / Santa Barbara Stucco - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-26-2018, 10:55 PM   #1
Rewards Points: 261
Patching smooth / santa barbara stucco
Hello and thanks,
Curious as to what the recommended steps are here.
Whole house is smooth stucco and we are turning a set of french doors into a window so we have some demo to do in order to flash the window and fill in the remaining door area...
Stucco man A says he can patch and blend just the area that is affected
Stucco man B says we need to skim the entire face this window is on (as in this entire wall until we hit a corner or isolation joint)
I do not have a problem with either way but wondering if one is preferred or if both can be done successfully without long term cracking, etc..
Again, feedback is appreciated.
beachfront71 is offline   Reply With Quote
Old 02-27-2018, 10:57 AM   #2
Rewards Points: 4,472
Re: Patching smooth / santa barbara stucco
The smoother the surface, the harder it is to hide a patch. I'd be tempted to hire the first guy if he agrees to most of his fee being paid at the end when I signed off satisfied with the job.
stick\shift is offline   Reply With Quote
Old 02-27-2018, 10:30 PM   #3
Rewards Points: 322
You state smooth?
Is it a smooth like Venetian finish? or a smooth sand float finish/
Is it colored or painted?
All of the above will effect what the finish affect would be.
Smooth Venetian Stucco man B is correct.
Sand float & painted Stucco man A should be able to float it out to match existing.
ClarenceBauer is online now   Reply With Quote
Revisiting stucco chimney repair Palmer5555 Building & Construction 3 03-16-2015 11:31 AM
New stucco over old painted stucco exterior Sandstone Remodeling 1 03-31-2011 05:26 PM
Smooth Stucco Shower Walls / Marble Dust michaelmarrin New Member Introductions 1 10-28-2010 12:39 PM
Smoothing Joints Between Sheetrock and Plaster Without Sanding OldManMike Building & Construction 6 06-30-2009 08:42 PM
Stucco on interior cmu/fireplace andys Building & Construction 1 06-24-2007 04:02 PM
