Partition Wall Framing Question - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By 123pugsy
Old 04-14-2017, 10:30 AM
Rewards Points: 4
partition wall framing question
hey all!
im remodeling my basement, and im working out this partition wall plan. The door will lead into the workshop, so the opposite side will be unfinished.
I've made a draft using sketchup. There are a few obstacles (2 HVAC ducts, and a PVC drain on the right). I plan on using a drop ceiling for this space as well as a soffit box around the PVC.
question: is this okay to not connect to the floor joists? I'll be fastening the wall on the L & R sides as well as concrete fasteners on the floor.
i'd appreciate any advice/comments/suggestions!
Thank you in advance!
damobu is offline
Old 04-14-2017, 10:33 AM
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,238
Re: partition wall framing question
2x4's are cheap. Just make another box on top in the big open space and you'll have a wall that doesn't shake when you close the doors.
MTN REMODEL LLC likes this.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline
Question on framing an interior wall adilj Building & Construction 12 01-03-2016 10:40 PM
Removing an Interior Wall Question prenger745 Building & Construction 11 04-08-2013 12:13 PM
New Partition Wall To Outside Wall TDD99CA Remodeling 2 01-29-2012 03:05 PM
Simple question regarding Wall Switch wiring kebrein Electrical 6 11-25-2011 07:54 PM
Easy question - Framing a stud wall 1jumper Carpentry 15 10-22-2011 08:07 PM
