Partial Block Foundaion - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-25-2010, 07:11 PM   #1
Partial block foundaion
I have just purchased a farmhouse in PEI, It has 3 courses of blocks sitting on dirt foundation as far as I can tell. Previous owner had started digging out the basment for hot water tank and storage, this stops about 2 feet from the blocks. So there is a wall of dirt about 4 feet high and 2 feet thick out to where the blocks are. I want to dig closer to the blocks and then either pour a wall or use 4" blocks to build a wall inside the existing block wall and up to the block wall that is already there, and then seal it somehow and then put a concrete floor in. Does this sound feasible?
Ontca is offline   Reply With Quote
Old 11-25-2010, 08:31 PM   #2
Rewards Points: 1,188
Not without one hell of a lot of work, planning, and experienced people to tell you how (or you help them) to jack the place up securely, then build your walls, etc. Digging near a foundation, whatever the material, can be very dangerous to people and building. You better not, IMO, try to figger this out over the Net. If you don't want to go to all that effort, and I suspect it will be a lot, can you get by w/ pouring concrete reinforced walls (engineer designed) well inside the "foundation dirt" and putting everything in that room? (ie, a smaller room below grade). Good luck; you've just tackled a big job!
The Following User Says Thank You to jklingel For This Useful Post:
Ontca (11-26-2010)
Old 11-25-2010, 11:34 PM   #3
Contractor
Brickie's Avatar
Rewards Points: 79
Absolutely not
Northwest Indiana Masonry
http://www.nwindianamasonry.com
Brickie is offline   Reply With Quote
The Following User Says Thank You to Brickie For This Useful Post:
Ontca (11-26-2010)
Old 11-26-2010, 06:59 PM   #4
Thanks, I know I have a project ahead, wish the money was there but will go slow and safe for sure
Door opening in load bearing block wall SS396 Building & Construction 12 09-13-2010 05:27 PM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-05-2009 11:02 PM
2x4s on block walls Captflx Building & Construction 4 08-24-2009 08:25 PM
Cracks In Block Wall Foundation vf100 Building & Construction 7 08-20-2008 09:48 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
