Pakistani Pile Driving - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-03-2015, 04:16 PM   #1
Rewards Points: 1,466
https://www.youtube-nocookie.com/emb...0nLCKypg?rel=0
Something to cheer up & confuse the Engineer in you.
Just to put you in the picture and keep you up to date with the latest developments.
Below is a link to a short video of a Pakistani pile driving construction technique!
The chant is also catchy!
Now, let's analyse the Engineering here:
6 men x 180 lbs = 1080 lbs static force.
Jumping up and down will create a 3 times dynamic effect = 3240 lbs/jump = 1.6 ton thumps if the pile is tapered to 2 in x 2 in, cross section at the tip = 4 sq. in. So, dynamic pressure/thump at pile tip = 3240/4 = 800 psi.
"Add a man" feature will increase to 950 psi, so buy the option!
Increase the chant and dynamic force goes up to 5 times to bring max.
pressure/thump to 1600 psi for a 7 man team.
Quite good, and will penetrate hard clay and sandy soil (but not hard or rocky ground!) Pretty ingenious.
Oh, the foreman is the guy on the tambourine.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
123pugsy (07-04-2015)
Old 07-03-2015, 05:31 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
not sure I agree with the calculations but it doesn't matter; it's fricken hilarious!!!!!!
Old 07-03-2015, 05:32 PM   #3
Journeyman Wireman
Rewards Points: 150
That was pretty cool. I need to use that method to drive ground rods.
Jupe Blue is offline   Reply With Quote
Vinyl Window Wool Pile Weatherstripping Replacement graybeard47 Windows and Doors 3 09-18-2014 08:50 AM
wooden pile for foundation mpj111 Building & Construction 7 04-16-2013 05:01 PM
compost pile bubbler Gardening Forum 27 09-26-2012 10:03 AM
Driving ground rods WillK Electrical 4 05-23-2011 08:14 AM
