Outdoor Fireplace Help Needed - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-18-2009, 08:48 PM   #1
I am buying a stainless steel insert outdoor gas/woodburning fireplace insert. Obviously I need to build around it. SHouldI create a wooden frame and sheath that or would it be better to use cinder blocks and add a facade to that? The inside will have stove flue of 8" but should not come in to contact with the cinder blocks. And how do I cap off the top, ie I will have a round pipe coming thru a square hole. I will have a flame arrestor/cap but how to fit around the pipe.
Thnaks all,
Tim in Houston
bohaiboy is offline   Reply With Quote
Old 08-18-2009, 09:32 PM   #2
Rewards Points: 1,016
Typically the fireplace supplier will provide detailed documentation of recommendations, clearances, etc. which will answer many of your questions.
Old 08-18-2009, 10:26 PM   #3
I am buying the FP insert from Direct Buy at an incredible savings over local retail and internet pricing, so I won't have that support.
Old 08-18-2009, 10:35 PM   #4
Concrete & Masonry
Rewards Points: 518
It's definatetly better to surround the FP with masonry, especially in an exterior application. It is more complicated to work with though IMO. As for capping off the flue, it sounds like a formed concrete cap may be the best option.
jomama45 is offline   Reply With Quote
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-25-2011 11:29 PM
Wire Needed for GF / Arc Fault breaker jamiedolan Electrical 13 09-20-2009 08:15 AM
calculating amount of exhaust vents needed bitty071203 HVAC 4 06-09-2009 07:13 PM
How Many Circuit's Needed dcd22 Electrical 7 09-13-2007 06:46 PM
