Outbuilding Project. - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By chandler48
  • 1 Post By Oso954
Old 05-26-2018, 07:51 PM   #1
Rewards Points: 360
Outbuilding project.
Ok, so my neighborhood has a couple of restrictions on outbuildings.
They can either match the material of the home or be located where they can't be seen from the street. I don't want to go to the trouble or expense of matching the brick and locating it in the rear where it can't be seen won't work either.
So I came up with a plan and actually got it approved. I am going to hide it behind a fence.
So what I am wanting to do it building it my side yard where I am going to build an 8' tall fence. The plan is to make the back of the building look like the rest of the fence which will just be a simple stockade style with the fence planks attached to the building instead of posts/rails.
I just need to know what type of waterproofing I need to do behind the fence boards?
Thanks.
herdfan is offline   Reply With Quote
Old 05-26-2018, 08:51 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 740
Re: Outbuilding project.
Build your building first, make sure it is flashed and painted well to prevent water infiltration. Then you can apply your "fencing" to the siding. You don't want to use DE fencing as siding, if that answered your question.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 05-27-2018, 06:16 AM   #3
retired painter
Rewards Points: 1,378
I'm thinking a plywood back wall, tar paper and then the fence boards.
mark sr is online now   Reply With Quote
Old 05-27-2018, 09:57 AM   #4
Rewards Points: 360
Thanks. What is DE fencing?
What about housewrap or Zip panels instead of tar paper?
Old 05-27-2018, 01:37 PM   #5
Naildriver
chandler48's Avatar
Rewards Points: 740
DE is dog ear fencing.
herdfan likes this.
Larry......
Old 05-27-2018, 02:58 PM   #6
Oso954's Avatar
Rewards Points: 642
Who approved this, HOA, building dept, or both ?
The reason I ask is that about 25 years ago, a friend of mine went round and round with his HOA to get a shed approved. Came up with the tall fence “solution”. My comment was good luck getting a permit.
Neither he nor the HOA knew that it would take a zoning variance to build the overheight fence.
chandler48 likes this.
Oso954 is offline   Reply With Quote
Old 05-27-2018, 06:56 PM   #7
Rewards Points: 360
HOA. No permit required where I am.
outbuilding electric bigpun0025 Electrical 16 06-30-2017 02:52 AM
Drywall project: New basement bathroom NetTractorTalk Drywall & Plaster 15 10-03-2012 01:23 PM
Troubleshooting 3 switches in one box for bathroom project Jerrys84 Electrical 11 08-01-2012 03:48 PM
New plumbing for bathroom in outbuilding on slab mnschu Plumbing 6 04-02-2012 03:13 PM
Interesting Project Mcamnl Electrical 14 05-27-2009 02:13 PM
