Opening Up Wall -do You Know What This Diagonal 2x4 Is? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-13-2014, 07:05 PM   #16
kwikfishron's Avatar
Rewards Points: 416
I framed in the East Bay for 3-4 years in the 80's and every exterior wall (on each end) and many of the interior walls perpendicular and tying into the exterior walls had let-in braces.
kwikfishron is online now   Reply With Quote
Old 10-13-2014, 08:34 PM   #17
Rewards Points: 1,290
Originally Posted by scottktmrider View Post
Cause I've been a carpenter for 25 years and never done this. I did see this years ago on exterior walls before plywood was used
I have never used an engineer on any remoulding I've done. when you work doing this for years and looking at house plans you learn loads. I allways over build but never had a house collapse or sag
He's getting a contractor to look at it, I am sure he's not an engineer
Wow , do it a few more years, run a lot of big commercial and industrial jobs with up to 50 guys on the job site at once and go to grad school, and you'll be right up there with me tiger
Anti-wingnut is offline   Reply With Quote
Old 10-13-2014, 09:12 PM   #18
Rewards Points: 454
I could never compete with you if I live to be 500 ,keep up the good work I am so proud of you,
I am sorry if I haven't spelled everything correct .
scottktmrider is offline   Reply With Quote
Old 10-13-2014, 09:30 PM   #19
Plumber
TheEplumber's Avatar
Rewards Points: 782
Years ago- in the 90's I had the privalige of framing in Seattle and LA. Both areas high on seismic.
I have never seen so many hold downs, clips, bolts, 3x studs, 4x studs, shear panels, panel blocking, strapping....
The Following User Says Thank You to TheEplumber For This Useful Post:
RockyMtnBlue (10-14-2014)
Header advice - wall opening.. Rwil85 Building & Construction 13 04-08-2013 08:43 PM
Opening up a living room wall claydiy Remodeling 14 12-07-2012 04:08 PM
Adding wall with door opening - sloped ceiling and no joist for top plate Jebross Remodeling 11 01-11-2012 09:34 AM
Opening a wall kmgilbertson Building & Construction 7 12-22-2011 07:35 PM
New opening in masonry wall Jeepsail Building & Construction 2 01-17-2010 02:50 PM
