Old School - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-03-2015, 12:38 AM   #1
Rewards Points: 12
Old school
I'm building a shop that has diagonal bracing on all walls, no plywood or OSB for racking support. I read a post that said Hardiboard should not be used over Celotex blackboard, and checked the Hardi site which has a form of disclaimer about it but has more to do with their warranty. Does anybody know if this is referring to a building that was improperly constructed with celotex as a racking preventer without diagonal bracing or ply/OSB in the corners, or is there an issue about moisture and breathing that is the problem? Celotex rates its breathablity higher than other options. My house is 60 years old, lap sided with pine 1X12's with Celotex underneath on all walls and have had no problems with it, and even used it 20 years ago in an addition, again with no problems.
CALNNC is offline   Reply With Quote
Old 07-03-2015, 01:49 PM   #2
AHH, SPANS!!!
Rewards Points: 1,166
structural plywood / osb is used on all outside corners of structure if black board or foam is used. plywood on your corners and house wrap and could be good to go for hardie siding...
hand drive is offline   Reply With Quote
Picking up a few tools before I leave for school ThomasHickey Tools 6 07-08-2012 11:59 AM
School personel being too sensitive? gma2rjc Off Topic 20 12-24-2011 02:06 AM
Plug outlet location in a new school prb_nearnorth Electrical 10 09-14-2011 04:45 PM
Buying a School luke_501 Off Topic 5 02-02-2011 12:15 PM
High School Student Remodel! dhenke92 Project Showcase 7 01-15-2010 05:40 PM
