Old Chimney, Many Cracks - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-20-2009, 03:12 PM   #1
old chimney, many cracks
The mortar on my grandmother's chimney atop her house is cracking just about all over. As a result there is a leak into the house. The obvious fix is to replace it, but I don't have the money. Being an old furnace chimney that used to heat the house, it is no longer in use. Is it possible to just chuck some wire around it and concrete over it? Or cover it over another way? What should I do?
Fixingranny's is offline   Reply With Quote
Old 11-20-2009, 03:15 PM   #2
Rewards Points: 582
Can you take it down below roof level and take the slates or tiles over it?
stuart45 is offline   Reply With Quote
Old 11-20-2009, 03:16 PM   #3
Remodeling Contractor
Is this chimney still used at all? The cracks may go all the way through and this would create a fire hazard. This happens because 80% of the chimney caps are built wrong allowing water to continue to penetrate the brick and motar joints. You need to do some more inspection to get a better handle on the condition. Post some pictures it may help us guide you.
Old 11-20-2009, 03:17 PM   #4
I'm not sure what you mean by this "chuck some wire around it" ?
You could possibly cover it with a tarp wrapped tight around it
If the mortar is failing then it might possibly fall over
Is this on an outside wall of the house, or does it go down thru the house ?
Any pics ?
Old 11-20-2009, 04:12 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,480
Ayuh,... I'm with Stuart,.... Knock it down below roof line, board over it,+ roof it....
Old 11-22-2009, 07:57 AM   #6
That may be just the thing. Thank you
Chimney Confusion (Long) wehcyar Building & Construction 10 02-12-2017 06:16 AM
Chimney Stucco Repair mikeyboy Building & Construction 7 04-11-2009 11:33 AM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 11:23 AM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 03:12 PM
