Notching A Stud - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-09-2018, 05:22 AM   #1
Rewards Points: 28
Notching a Stud
I'm installing a microwave on an exterior wall and want to vent it out the back through the wall. There is a stud just on the edge of where the vent needs to go. I read that you can notch a stud up to 25%, but the accompanying pictures only show the notch on the short face of the stud. I need to notch the wide face. No more than 3/8" will be notched, about 4" tall. Is this ok?
ST180 is offline   Reply With Quote
Old 07-09-2018, 05:43 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 1,340
Re: Notching a Stud
3/8" will not compromise the stud.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 07-09-2018, 06:55 AM   #3
JUSTA MEMBER
Rewards Points: 1,628
Re: Notching a Stud
1 & 5/8 - 3/8 = 1 & 1/4 inches.
Which should be adequate support for the structure in that area.
If you get it precise you should be fine, but much more and you might have problems.
Is there a way to sister another stud to it on the opposite side from the notching, as a precaution?
I tend to over structure things as a safety measure.
ED
de-nagorg is offline   Reply With Quote
Old 07-09-2018, 09:25 PM   #4
Rewards Points: 1,676
Re: Notching a Stud
Absolutely no worries at all.
ront02769 is online now   Reply With Quote
Help! Accidentally bored through a stud Hobastian Carpentry 12 06-28-2017 11:33 PM
Very wide wall stud - how do I know if it's a double or triple stud? Druidia General DIY Discussions 11 08-29-2016 04:49 PM
When to replace rotted stud vs. epoxy ken57 Building & Construction 4 11-08-2011 07:48 AM
Notching stud question b_corwin Plumbing 8 01-18-2011 11:24 PM
Moving a Stud HooKooDooKu Building & Construction 5 02-23-2010 02:11 AM
