Non Load Bear Wall Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-11-2010, 10:15 AM   #1
non load bear wall question
I'm working in a commercial space where a previous tenant did some lousy remodeling. He framed non load bearing walls right up to the metal ceiling beams. The beams span 40 feet and the ac unit is on the roof, so there's a little bit of give in them. The sheetrock on the walls he framed is cracking, I assume because the beams are pushing down on the frame. I'm worried, too, about the long-term affect this will have on the foundation. I'd rather not rip out the entire framing and start over.
My question is, can I cut out a small gap -- like 1/4" -- on the top plate where it rests under the beam, thereby giving the beam a little breathing room?
Thanks.
Repass is offline   Reply With Quote
Old 10-11-2010, 11:30 AM   #2
STRUCTURAL
YES, YOU CAN (HOPE AND CHANGE)
No problem repass as long as you are sure that these are not load bearing and that the beam is not damaged in any way.
http://www.chmconsultants.com/Light-...lServices.html
ENGINEER10 is offline   Reply With Quote
Is this wall load bearing - pictures attached jen5219 Building & Construction 16 08-01-2010 01:17 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Question about removing trim wall in foyer cary00silve Remodeling 1 02-02-2010 01:02 PM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-21-2010 12:26 AM
Load Bearing Wall??? please help shenmon Building & Construction 6 01-24-2009 11:07 AM
