No Vapor Barrier - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-22-2010, 08:07 PM   #1
No Vapor Barrier
Hello everyone, I have a question about vapor barrier. We are in Northern Canada and own a house that currently does not have vapor barrier in the walls, just insulation. I know that back in the day it was not required to have a vapor barrier...is there anything that we can do to this house to actually make a good vapor barrier in the house without having to tear out all the drywall? Thank you.
kriskizlyk is offline   Reply With Quote
Old 05-22-2010, 09:46 PM   #2
Rewards Points: 6,652
You can't. If the insulation has the Kraft paper on it, you are already good to go. Only way to do it properly if needing to update wiring, and replace old plaster walls if still, is to tear down to the bones and start from scratch.
Old 05-23-2010, 02:49 PM   #3
Registered User
Rewards Points: 526
http://www.applegateinsulation.com/C...id=249418&fd=0
http://www.energysavers.gov/your_hom.../mytopic=11810
Be safe, Gary
