New Windows/nailing Flange - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-07-2008, 08:50 AM   #1
New windows/nailing flange
Anyone else finding that the thickness of the nailing flange on new construction windows makes for a lot a lot of shimming to install trim or is it just me?
white29 is offline   Reply With Quote
Old 09-07-2008, 11:15 AM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
I'm assuming your talking about the exterior of the window trim. When i install trim around a window with a nailing fin I don't shim. What i do is rip the thickness of the fin out of the back of the trim. On a table saw ( rabbit) This way when installed it will lay flat.
Old 09-07-2008, 11:42 AM   #3
Yeah,that alternative did present itself to me. Maybe for the final two windows I've got to install I'll go that route. I'm using windows with integrated J channel,3/4 trim which will be wrapped and hardiplank siding.Thanks for the response.
Old 09-07-2008, 11:56 AM   #4
buletbob's Avatar
ANYTIME! BOB
Old 09-07-2008, 10:00 PM   #5
Are you leaving room for the backerrod and sealant joint?
stuccoman is offline   Reply With Quote
Old 09-07-2008, 10:08 PM   #6
Rewards Points: 1,100
Speaking of windows, I can't find the drainage holes on the bottom of my windows. Caulk must have covered them up, and now when it rains, the wells fill up. This is a 10 year old house. Does anyone know if all windows generally had drainage holes?
handy man88 is offline   Reply With Quote
Old 09-07-2008, 10:10 PM   #7
HM88
What kind of window?
Old 09-07-2008, 10:23 PM   #8
Originally Posted by stuccoman View Post
HM88
Vinyl dual pane.
Old 09-08-2008, 07:37 PM   #9
Please explain backerrod and sealant joint,stuccoman.
Old 09-09-2008, 04:35 AM   #10
Look on page #5
http://pro.pella.com/pdf/clad_doublehung.pdf
Old 09-09-2008, 07:11 PM   #11
Ok Stuccoman,thanks for the clarification. I figured that was what you meant. Those instructions do not pertain to windows like mine with an integrated J channel. I did caulk behind nail flange and apply flashing tape to the rough sill and over the outside face of the flange. The trim is then butted into the J channel and I caulk the outer edge before the trim is wrapped in aluminum by the siding guy.After the trim is wrapped I put the hardiplank on,leaving their specified gap (1/8" I believe) between hardi and trim.Then this joint is caulked. The only other thing I'd like to do on these windward side windows is to put some kind of drip cap on the top piece of trim.
Old 09-09-2008, 10:06 PM   #12
white29
Check your private messages
And what are you going to do with the sills?
cast iron flange Jrebhun Plumbing 2 09-06-2008 01:45 PM
Replacement toilet flange for Iron rgb407 Plumbing 9 08-27-2008 08:40 PM
Toilet Flange and Flooring brneilly Remodeling 4 04-20-2008 12:37 PM
Toilet flange floor advice Hobb3s Plumbing 6 04-15-2008 10:41 AM
Flange Help Needed tajones44 Plumbing 2 07-11-2005 05:42 PM
