New Stair Teads - Yello Pine - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-05-2009, 04:13 PM   #1
Rewards Points: 87
New stair teads - Yello Pine
I would like to rip up the carpet on my stairs and replace with wood finish. Unfortunately we don't have the budget for hardwood Oak stair treads at nearly $30 each plus other supplies. I found we can get yellow pine stair treads for less than $10 each and they have a nice grain pattern and NO knots.
1. Am I wasting my time with yellow pine for stair treads compared to a hard wood?
2. Can yellow pine be stained and finished for good appearance?
If there is no alternative to using hardwood treads, such as oak, then we may just resort to new carpeting. I appreciate any advice or comments you may have.
DK75 is offline   Reply With Quote
Old 11-06-2009, 05:37 AM   #2
Remodeling Contractor
the pine treads will be fine. You can stain them any way you want. You will need to use a pre-conditioner prior to the staining. The softer wood will be blotchy if you do not do this.
Why can't I find a good thatch rake or pine needle rake? carl1864 Landscaping & Lawn Care 5 06-05-2011 01:01 PM
Oak hand rail on existing iron stair railing dougworm Carpentry 8 05-03-2011 05:54 PM
sanding pine stair treads. Need adivce. Mike in Arkansas Flooring 2 07-20-2009 10:01 AM
Lighting for stair risers jweiner Electrical 2 04-06-2009 05:18 AM
White Pine Hard-Wood floors? MrShadetree0222 Flooring 9 11-04-2008 08:24 AM
