New Shed Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-18-2010, 04:13 PM   #1
lloydb's Avatar
Rewards Points: 79
New shed floor
My neighbor gave me a 10'x16' shed with the floor rotted out.
I've put new 2x6 floor joists every 2' under the shed and the ends are supported by cinder blocks.
Do I need additional support for the floor in the middle of these 10 foot 2x6 joists?
Thanks so much
lee
Broken Arrow hvac Broken Arrow Air Conditioning
lloydb is offline   Reply With Quote
Old 10-18-2010, 04:33 PM   #2
jlhaslip's Avatar
Rewards Points: 708
Even if the new joists are in the 10 foot direction, I would put some form of centre support under them.
What are you using for flooring?
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 10-18-2010, 04:40 PM   #3
lloydb's Avatar
Rewards Points: 79
I bought 5 sheets of 23/32 plywood. Think that'll be good enough?
Old 10-18-2010, 04:48 PM   #4
Civil Engineer
Rewards Points: 5,246
Whether it is good enough depends entirely on what you are putting in there. I have a shed with 3/4 inch wooden boards supported on partially rotten joists, it works fine because I store a few light tools in there, and walk carefully on the floor. The same shed would be totally bad news if I wanted to store a tractor in there, or bags of cement, or wood.
Old 10-18-2010, 05:32 PM   #5
lloydb's Avatar
Rewards Points: 79
I'm planning on moving my woodoworking operation out there along with a riding mower.
The mower is probably the heaviest with my jointer being second.
I guess I should do something to support it while I can still get to it.
How to anchor toilet flange to porcelain tile? bobmg Plumbing 32 08-19-2013 09:32 PM
How do I stop water from getting under the floor of my plastic Lifetime shed. Ckeith Building & Construction 4 08-31-2010 11:54 AM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 12:11 PM
shed floor plywood layout? flamtap Carpentry 4 04-24-2009 11:20 AM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 04:58 AM
