New Deck And Patio - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-23-2015, 12:44 PM   #1
Rewards Points: 2
New deck and patio
We recently bought a 2 story house built in 1983 in Minneapolis, MN.
It currently has no deck or patio. It's a walkout lower level so a patio is a must but I'd also like a deck above the patio on the 2nd floor.
Not sure if I want to do concrete or brick for the patio. Is there an order as to which I should install first? Deck and then patio or patio and then deck?
I can't afford to do both this year. I'm assuming if I installed the patio first I'd either have to also do the footings for the deck at the same time or tear up part of the patio and install the footings with the deck install next year.
What is the smartest/cheapest option?
ross7777 is offline   Reply With Quote
Old 04-23-2015, 04:07 PM   #2
Rewards Points: 18,384
I'd build the deck first.
Find out what all your local codes are, building dept. may even have a hand out.
A second story deck is a whole different ball game.
Old 04-23-2015, 05:32 PM   #3
Rewards Points: 1,678
I would DESIGN fine deck first, Mark the footings, and then 1) if they are IN the patio, put them in and then the patio or 2) if they are outside of the patio, just do the atoo now. Either way, get that patio in first as you'll use it and love it all spring summer and fall. Ron
ront02769 is online now   Reply With Quote
Old 04-23-2015, 05:57 PM   #4
Property Mgt/Maint
Rewards Points: 7,630
build the 2nd story deck first, going to require substantial footings, anything below the deck is going to take a lot of abuse during the build. But once its in you'll have a dry shady work space below to finish the patio
[political signature removed]
Yodaman is online now   Reply With Quote
Old 04-25-2015, 08:40 PM   #5
Knucklez's Avatar
Rewards Points: 1,002
yodaman, sounds like you did it the other way around once
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Old 04-25-2015, 09:47 PM   #6
Property Mgt/Maint
I have done it. But did complete the balcony deck first. 24 x 24 x 6 footings went in first, topped w/ 16 x 16 pier to above grade. The 6 x 6 post and braces have a tenon connection with the triple 2 x 8 built up beam. Was constructed all together on the ground and raised as a single unit. OAL size is 22 x 10. Also used 2 tiers of scaffolding to assist with joist structure.
Could not imagine trying to build it over a finished patio!
Poured concrete and built the winder steps below after
The Following User Says Thank You to Yodaman For This Useful Post:
oh'mike (04-27-2015)
Old 04-27-2015, 06:52 AM   #7
Rewards Points: 4
I think you should build the deck first and then the patios. Sothat you will have a dry shady work space to finish the patios.
Susanjforney is offline   Reply With Quote
Backyard Project - Patio and a Deck OKDrew63 Building & Construction 16 07-16-2012 04:32 PM
how to transform concrete patio into deck IsabellaS Landscaping & Lawn Care 5 07-04-2012 08:41 PM
Ideas for deck over concrete patio and beyond-pics- bdobs General DIY Discussions 11 10-22-2010 09:50 AM
Patio Around an Existing Deck tonyg Landscaping & Lawn Care 1 09-10-2009 07:57 PM
Ideas for deck over concrete patio and beyond-pics- bdobs Building & Construction 6 05-10-2009 09:58 PM
