Need Suggestions For Leaking Basement Addition - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-28-2015, 09:15 AM   #1
Need suggestions for leaking basement addition
Hello,
My wife and I are currently in the process of buying a new home. We have found one that we really like, but had a very large negative aspect to it. Sometime in the past the old owners wanted to put an addition on it. They dug a 13'x20' basement, put in a wood foundation, cut a doorway into the current basement and then put the joists in and subfloor.
Somewhere they must have ran out of money because this is where the addition ended. They covered this with black plastic and installed a deck over the entire area to hide it. Now this bandaid has become an issue. The plastic has worn and is allowing water to seap through the subfloors and drip into the basement.
We are curious what our options are to permanently remedy this problem. We don't have the money to put the addition on.
Thanks for any advice!
Sb16 is offline   Reply With Quote
Old 06-28-2015, 10:34 AM   #2
craig11152's Avatar
Rewards Points: 1,220
Wow.....off the top of my head I assume the joists and subfloor are not pressure treated? The building inspectors aside replacing joists and subfloor with pressure treated and maybe even marine grade plywood. That would give you a weather resistant surface that would barely leak. After that outdoor carpet?
Are you in a buyer or sellers market?
Don't look at me. I didn't vote for either one of them.
craig11152 is offline   Reply With Quote
Old 06-28-2015, 10:42 AM   #3
Correct, the joists and subfloor are not pressure treated, just regular wood then covered in the plastic.
That was just about the only idea I came up with was to replace the subfloor with a pressure treated type and cover that with a shingle or metal roof with a very slight grade away from the house. Then put a new deck over the entire thing to cover it.
Old 06-28-2015, 11:50 AM   #4
craig11152's Avatar
If your going to roof the thing it doesn't need to be pressure treated. As to roofing I would think an EPDM,SBS or APP would be your best bet. Do the current owners have equity in the house? If so you could aim for cash back at closing to deal with the mess.
Old 06-28-2015, 12:22 PM   #5
craig11152's Avatar
Upon further review you want to be sure that unfinished project isn't a legal issue.
Old 06-28-2015, 12:30 PM   #6
Rewards Points: 469
If it truly has a wood foundation and not concrete block walls and its holding back backfill I would turn around and run, There are a lot of codes on a wood foundation that need to be followed to keep it from self destructing. If this is a addition that's not holding back dirt that's a different story
Jnaas2 is offline   Reply With Quote
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 11:08 AM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 09:49 AM
22x22 addition, basement workshop, mater bedroom above. iMisspell Project Showcase 26 07-21-2009 02:35 PM
Basement Addition showtime14 Building & Construction 9 03-10-2009 07:08 PM
