Need To Size A Steel I-beam - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By rjniles
Old 08-02-2016, 04:18 PM   #1
Need to size a steel I-beam
I've tried to look online for a steel ibeam that would be sufficient in my situation. I am building 22x32 living quarters in a pole barn. I was going to put bedrooms upstairs and want a beam to be 20' long to support the second floor without any beams. I was thinking 11' 2x10" for floor joists that will use hangers on the beam instead of on top of beam. Any idea on the size on ibeam needed? Thanks
Remington2225 is offline   Reply With Quote
Old 08-02-2016, 04:33 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 224
Re: Need to size a steel I-beam
You need a structural engineer.
de-nagorg and stick\shift like this.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 08-02-2016, 07:41 PM   #3
Civil Engineer
Rewards Points: 5,246
Steel beams are sized based on the load, the span, and the connection details. There are usually many different beams that will work, your structural engineer will decide which is best based on the available space, the loading, the cost, and the support post requirements. You are not going to find an on line site to size your beams, almost always individually sized by an engineer or architect.
L shaped porch framing onjtrainee Building & Construction 34 02-07-2015 08:10 PM
Connecting floor joists to steel I beam craigjohnson Building & Construction 8 07-29-2014 09:01 AM
Steel I BEAM size whatsupteach Building & Construction 11 04-16-2012 02:19 PM
What size beam to support loft with 16' between supports paperman Building & Construction 3 10-06-2009 06:40 PM
attaching garage loft support to 12 inch steel I beam lospinoj Building & Construction 4 09-14-2009 02:38 PM
