Need Remodeling Advice! Structure - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-08-2010, 07:47 PM   #16
Thanks so far, guys...I have an architect friend who will be taking a look at this.
echelonphoto is offline   Reply With Quote
Old 01-08-2010, 07:51 PM   #17
One obstacle I just realized is that the center of the ridge beam winds up over the sliding door on the outside wall...so I would probably have to put some hefty engineered lumber as a header over there...or I might just change it to a single door.
Old 01-08-2010, 08:10 PM   #18
Or you could put a door on either side of the support post
One that is fixed....one that opens
Might even be able to use the panel from the existing slider
IF this was built correctly there is already a hefty header over that slider
BUT may need to be bigger since the load is changing
Old 01-09-2010, 08:51 AM   #19
Good idea, Dave
Old 01-09-2010, 12:39 PM   #20
Framing Contractor
The Architect will tell you what size header to put in to support a structural beam if you go that route. No need at all to move your door. This is normal framing.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 01-10-2010, 10:40 AM   #21
Here's one really good solution I may be able to use!
http://www.metwood.com/
Ideas Regarding Kitchen Remodeling Kristal Kitchen & Bath Remodeling 2 12-20-2009 09:44 AM
Need help with underground structure terminologies Jubinell Building & Construction 5 12-02-2009 09:39 AM
