Need Patio/Concrete Slab Advice - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-01-2010, 03:41 PM   #16
Rewards Points: 16
ok, I see your point. Thanks for the explanation. Having watched them dig the foundation to my house, I can attest to there being a lot of rock underneath, but how far down until they hit that rock, I am not certain. Also, I know that they backfilled quite a bit around the foundation, and so I might have many more feet of soil before I hit rock around the house than 25 feet away from the house. I have been under the assumption that a concrete slab was the "safe bet"--maybe that is what the original guy was selling. Thanks again.
rsbst19 is offline   Reply With Quote
Old 01-01-2010, 10:28 PM   #17
Rewards Points: 426
http://www.paveloc.com/pages/diyp3.html
High Gear is offline   Reply With Quote
Old 01-02-2010, 08:06 AM   #18
Rewards Points: 360
If you ever have a problem with the pavers like heaving or sinking it is easily fixed with a little labor, a plate compactor and a few buckets of crushed stone. You usually can't tell it was repaired.
Rege
RegeSullivan is offline   Reply With Quote
Pouring Patio Slab and Post Footings Question average_male Building & Construction 22 04-04-2016 12:13 PM
Advice needed - Use ABS or PVC for waste pipe under our basemenst slab? drh Plumbing 4 02-03-2008 06:27 AM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 12:50 PM
