In Need An Opinion - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-10-2015, 01:35 PM   #1
Rewards Points: 84
In need an opinion
I'm about to replace an existing exterior french door with two windows. Currently the door is flanked by two 29" x 59" casements that are actually close enough to share the exterior 4" trim. I have ordered two idential 29" windows to we will have a bank of four identical windows when it's done. However, my question is in the window spacing.
If I measure the opening width from each existing window I have 80" (72" door plus 4" trim on each side). To evenly space my new windows in the opening I'll have roughly 7" of space now between each window. (80 - 29 - 29 = 22, 22/3 = 7.3"). So my trim between each window would now be the 7.3" if I filled it in solid. There is no trim wide enough to do this in one piece, nor am I sure I would like the look.
Another option is to maintain the 4" spacing between the windows on each side and leave a 6" gap for siding between the two center windows. (72 - 29 - 29 - 4 - 4 = 6). But now we don't have the equal spacing and I'm not sure it would look right with that small variation.
Sorry, I don't have any tools to draw this up so I hope everyone can understand my layout.
Any opinions or other options?
jmyers63 is offline   Reply With Quote
Old 06-10-2015, 04:17 PM   #2
JUSTA MEMBER
Rewards Points: 412
Try moving the existing windows in a bit, then divide the 22 by 5 and get a 4.5 inch gap.
de-nagorg is offline   Reply With Quote
Old 06-11-2015, 12:25 AM   #3
Rewards Points: 2,264
It is totally a looks thing and you have to decide which is best for you.
The suggestion above is a good one too. But may call for restructuring of headers and the opening depending on how it was built.
mae-ling is offline   Reply With Quote
Old 06-11-2015, 08:49 AM   #4
Rewards Points: 84
If I move the existing windows in, I'm dealing with sheetrock and existing moldings on the inside. It's all brand new in there so I'd like to now start over inside.
Old 06-11-2015, 09:42 AM   #5
AHH, SPANS!!!
Rewards Points: 1,166
5/4 pvc trim comes in sizes up to 11 1/4" wide. sometimes it looks better to add siding up between the windows, kind of depends what type of siding etc...
if you have 5/4 trim there you could run the top horizontal piece fully across and the bottom and fill in between with the verticals.
hand drive is offline   Reply With Quote
Opinion on Ruud RA13 Single Stage(SEER 13) Achiever Series 3-Ton bern8277 HVAC 1 05-29-2015 12:38 PM
Cracks in Arches-need your opinion melswan1 Drywall & Plaster 3 07-11-2014 12:42 PM
WELDING.. need an opinion or solution to a problem chem Building & Construction 2 06-16-2012 07:37 AM
J-B Weld to Mount Metal Box HooKooDooKu Electrical 161 02-04-2010 12:12 PM
Need opinion on Subfeed ANDYHD Electrical 2 03-12-2008 01:46 PM
