Thread Tools | Display Modes |
#16 |
retired framer
Rewards Points: 1,748
![]() Re: Need help replacing old rafters when specs call for bigger ones
The joist is there to be a rafter tie which is to hold the outside wall straight.
So the rafter is nailed down to the wall and can't move out. the force on the rafter is pushing against the brick wall so a straight cut with just nails is fine. But I would fill the space above that ledger so you can cut the rafter with out the notch. Attachment of the spacer above the ledger is not all that important because any weight on it will bear down on the ledger. |
Sponsored Links | |||
Advertisement |
#17 | |
Rewards Points: 22
![]() Re: Need help replacing old rafters when specs call for bigger onesQuote:
Advertisement |
#18 | |
retired framer
I don't know if that is a rule or just common practice. I have worked mostly with trusses for the last 20 years. |
Advertisement |
#19 | |
Rewards Points: 22
1) What sort of material/connection is adequate to build up the upper ledger to accommodate hangers and the 2x10 LvL rafters (which will now be installed without compromising their strength with a level and plumb notch). 2) What sort of bracing or horizontal ties are necessary at a minimum to secure the outside wall from being pushed. I'm confident I can get an engineer's opinion on that and I'll posy back here what he/she says. Thanks! |
#20 | |
retired framer
2x6 would be fine for the rafter ties you can add a 2x4 from the rafter down to the tie to hold it up in the center. |
#21 | |
Rewards Points: 22
Also I'm still seeing using the hangers as the solution for maintaining my crown height (deck height) as it was with the old 2x6s, since hopefully by using the hangers and only a plumb cut, the whole 2x10 beam could be installed lower down so that its crown matches the crown height of the old dimensional 2x6 rafters. Maybe that could be accomplished with a deeper cut into the new 2x10s? I'm out of my league there. But either way I like the idea of keeping the LvLs as strong as possible end to end if I'm going to spend the money on them. That being said, I don't know much about what I speak! |
#22 | |
retired framer
The can be cheaper, when you are talking about LVLs. They could build them to sit on the lower ledger, they just design them around that needed notch or tell you what you need to do. The would need exact location of the two ledgers., the slope you have and the heel cut. Heel cut. If you were to order say 14 ft trusses. At that 14 ft mark at the edge of the wall you measure up to the bottom of the sheeting. maybe plus 1/4" if you are using thinner sheeting. So the finished height would be the same. |
#23 | |
Rewards Points: 22
Nealtw likes this.
Advertisement |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
No water after replacing shower washer a few hours ago | vcsolit | Plumbing | 15 | 06-30-2018 01:39 PM |
checking the rafters | joefromcal | Carpentry | 3 | 10-01-2010 09:12 AM |
Replacing rafters, but no ridge board | WillK | Building & Construction | 0 | 08-29-2010 09:44 AM |
Gas Heater -- Fan with Call for Heat?? | gadha | HVAC | 2 | 02-16-2010 03:03 PM |
Replacing roof rafters | DMD | Roofing/Siding | 10 | 02-15-2010 05:52 PM |
