Need Help??? Newly Poured Concrete Around Pool Is Too Rough! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-24-2010, 01:45 AM   #1
Need Help??? Newly poured concrete around pool is too rough!
We just had a inground pool installed. The concrete around the pool was poured on Wed. They did a broom finish but it's ROUGH!!! What can we use to make it less rough? It hurts my bare feet to walk on it! I know that it can't be too smooth or people will slip & fall, but it's way too ROUGH? Anyone have any suggestions? They are not going to come back and fix it either which is the upsetting part because they are non-americans who work for the pool company.
Ms TAB is offline   Reply With Quote
Old 09-24-2010, 07:44 AM   #2
Rewards Points: 5,348
There are machines that can reduce the roughness. You would need to call in a concrete guy to do the job.
Ron
Old 09-24-2010, 07:47 AM   #3
Household Handyman
Rewards Points: 1,412
You're not going to like this answer, but it's a proven one. I've seen this too many times. You can take a regular concrete block, cinder block in some areas, tie a heavy cord/rope to it, and pull it around the new deck area to help smooth this roughness out. If you don't like this method, there are hand held blocks, lava blocks, which you have to get on your knees to use to do this-NOT for me. Then there are power trowels which you can attach stones to for this. Expensive, and not for a DIY. So, use the concrete block and every time you walk one way or the other, pick up the rope and pull the block. You don't have to do this all in one day. The bottom line on this: What was agreed to between YOU and the POOL CO. ?
Good Luck, David
Old 09-24-2010, 02:43 PM   #4
Rewards Points: 3,622
since you haven't paid for unacceptable work, my guess's they'll be back
Old 09-24-2010, 07:54 PM   #5
Rewards Points: 506
you could try a garage floor paint, but that would probably be too slick.
forresth is offline   Reply With Quote
Old 09-24-2010, 08:50 PM   #6
jlhaslip's Avatar
Rewards Points: 708
grinder and a cup stone
for example: http://ww28.quickb.info/united-abras...up-stone-26001
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 09-25-2010, 01:42 AM   #7
Rewards Points: 1,188
I'd use the stone grinder first, as suggested above. I BELIEVE that there are anti-slip paints made for concrete, just like Durabak (sp?) and others that make anti-slip for boats, etc. The stuff is very thick and would help bury any burrs left after grinding. Note: Grinding concrete is hard, hard work, and very slow.
Newly refinished hardwood floors are too rough StevenSmith Flooring 11 09-25-2010 08:03 PM
Small holes forming in newly poured concrete chitownIrish Building & Construction 4 07-10-2010 02:24 PM
Deck Piers vs Poured Concrete Footings McSweny1103 Landscaping & Lawn Care 5 06-16-2010 06:47 AM
Joining poured concrete and concrete blocks ws450r Building & Construction 3 12-31-2009 06:05 PM
Best (easiest) way to drill into poured concrete wall Todd-sta Building & Construction 11 11-16-2008 03:57 PM
