Need Help With Covered Patio - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Str8AheadInc
  • 1 Post By jlhaslip
Old 03-08-2017, 10:30 AM   #1
Rewards Points: 8
Need Help with Covered Patio
Hello.
So we are attempting to build a 16 x 20 attached patio. I have a concrete pad so I will be attaching posts to the pad. I plan on running a 2x12 ledger board against the house. I will have 3 posts @ 10ft for the beam. The span from the house to the beam will be 14' with a 2' overhang using 2x6 for rafters. Wife wants a rustic look so it will be covered with Galvanized Steel Utility Panels.
1. Is the 2x12 ledger board the right size?
2. Will running (2) 2 x 10 on each side of the posts hold up the 2 x 6 rafters?
Any help would be appreciated!
robstapp1985 is offline   Reply With Quote
Old 03-08-2017, 10:45 AM   #2
JUSTA MEMBER
Rewards Points: 306
Re: Need Help with Covered Patio
Sounds right.
A tip you can never overbuild , so add strength anywhere you can.
You have a sound plan, and without more information (picture, actual eye on, etc.) I cant advise much more.
Use more than the bare minimum bolts to attach to the house, use more.
ED
de-nagorg is online now   Reply With Quote
Old 03-08-2017, 11:14 AM   #3
Rewards Points: 8
Hope this helps
Old 03-08-2017, 04:51 PM   #4
Professional
Rewards Points: 188
Originally Posted by robstapp1985 View Post
Hope this helps
I'd go 16 o.c. with joists and jump up to 2x10 bc I like no bounce.
Where do you live? 2x6 would not be good if you had load.
Picture?
Str8AheadInc is offline   Reply With Quote
Old 03-08-2017, 04:56 PM   #5
Professional
Rewards Points: 188
I guess we overlapped when you posted your pic. I thinks its easier to use the same size ledger as joists. I secure my ledger first and then I put a rim over it with my joist hangers already nailed on layout and flash appropriately before decking. Your beam and cantilever are fine (except under load). A snaphot of the work site would also be helpful. I echo the sentiment above about overbuilding on deks, a few dollars more now makes a difference down the road....
de-nagorg likes this.
Old 03-08-2017, 05:49 PM   #6
jlhaslip's Avatar
Rewards Points: 708
Even a 2 x 10 will be terribly close to maximum span at 14 ft.
http://www.awc.org/codes-standards/publications/dca6
Table 2 for Joist Spans
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 03-08-2017, 05:55 PM   #7
Professional
Rewards Points: 188
I thought he was talking about the carrier beam under his rafters as far as spacing. I think he can get away with 2x10 but, you're right, 2x12 is the way to go.
Old 03-08-2017, 06:12 PM   #8
jlhaslip's Avatar
Rewards Points: 708
That PDF I link to has a bunch of good information.
I don't think bolting a 2 x 12 to each side of the posts to act as a Beam is the right way to go.
The PDF has info on that as well.
Old 03-08-2017, 06:15 PM   #9
Oso954's Avatar
Rewards Points: 294
The way i read it, he is building a patio roof, not a deck. The patio roof rafters use a different span table than joists (at least in my state).
Here is an example from a city about a hour away from me. It is a no snow load area.
http://www.ci.concord.ca.us/pdf/perm...patiocover.pdf
Oso954 is online now   Reply With Quote
Old 03-08-2017, 06:22 PM   #10
jlhaslip's Avatar
Rewards Points: 708
My bad. Thanks for catching that.
Oso954 likes this.
Old 03-08-2017, 07:32 PM   #11
Professional
Rewards Points: 188
PHP Code:
[IMG]]https://alaskaninteriorbuilders.files.wordpress.com/2013/08/img_0529.jpgN[[/IMG]
There's nothing like building a deck on a sunny day...
Old 03-08-2017, 08:57 PM   #12
Professional
Rewards Points: 188
That was supposed to be a nice pic of my crew on a sunny day. Ha
Converting covered patio into a sunroom mikeinMemphis Building & Construction 12 12-23-2013 11:49 AM
Help with ceiling color for covered patio dvp416 Interior Decorating 3 06-10-2012 03:07 PM
covered patio dvp416 Interior Decorating 1 06-08-2012 05:24 PM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 01:45 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 09:06 AM
