Need Clarification On Different Types Of Wall Panel - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-10-2009, 02:17 PM   #1
Need clarification on different types of wall panel
I've been trying to piece together information about the different panels available for walls. I haven't seen all of this information in one place, and have been confused by conflicting information. Can someone help verify my information?
Drywall
Generic term for any panel that uses a gypsum core.
SheetRock
USG's brand of drywall (sheetrock is to drywall as kleenex is to tissue paper?)
Blue Board
Drywall with a special blue paper used for veneer plaster. The special paper absorbs water from the plaster and gives it a surface to adhere to.
Imperial Gypsum
I *think* this is USG's brand of blue board?
Green Board
Drywall with moisture-resistant properties. Like regular drywall, you paint over this.
Durock
This is a cement-based board generally used in a bathroom behind tiles.
WonderBoard
Does the same thing as Durock
Fiberock
A gypsum-fiber panel that can be used in the same way as Durock. Not sure of the pros/cons versus Durock.
Now, for my particular situation, I'm looking at doing some work in my bathroom. Here are my application-specific questions:
  1. For non-shower walls, should I use green board, or blue board? (with blueboard implying that I need to plaster)
  2. What do I use on the ceilings? I've heard that green board will sag.
  3. If I plan on doing anything behind my shower/bath tiles, I need to use a cement-based board, or Fiberock, right?
  4. How come homedepot.com and lowes.com don't sell anything called "blue board" or "green board"? What exactly should I be looking for?
mspiegle is offline   Reply With Quote
Old 08-10-2009, 02:50 PM   #2
Remodeler
adpanko's Avatar
Rewards Points: 150
Your summary of the different names/types of panels appears dead-on. I think the Fiberock might be slightly off, as I don't think this is as concrete-ish as the Durock and Wonderboard, but appears more gypsum looking (it is a brand name of USG product; see USG's website for good descriptions of all their products).
But basically, the verdict is mixed on greenboard. It is the same core stuff/gypsum as "regular" drywall, but its paper surface is water resistant (and green in color). It is NOT water proof; if/when water penetrates the paper, it will turn the gypsum core to mush just the same as normal drywall. A lot of people in construction feel greenboard isn't worth the couple of dollars extra per sheet for minimal improvement in water resistance, but others swear by it. I personally don't use it.
For your bathroom, I'd recommend the following: "normal" 1/2" drywall on all walls and ceilings. As for behind the tub/shower, it depends what you are putting up for walls. If you're doing tiled surounds, then use Durock or Wonderboard directly to the studs, then tile on top of the Durock/Wonderboard. If you're doing tub surround walls, I'd say you can still just do normal 1/2" drywall as on the studs, then glue the surround walls up to that. Check your local code though; it may require greenboard behind surround walls.
Here are my thoughts on Durock/Wonderboard vs gypsum based materials behind surround walls: Tub surround walls only have a few spots where water can get behind (ie only the corners and where fixtures are), and those spots are easy enough to seal up well. So the chances of water getting behind surround walls is small if you put in your surround walls properly, so I'm comfortable using drywall. As for tile, there is a MUCH greater chance of water getting in between the tiles over time, so you want a concrete backer. Concrete backers don't block water from getting through to the studs/insulation, but they will not break down, turn to mush or otherwise lose integrity at all. Gypsum products, on the other hand, will turn to a mushy mesh when they're wet.
adpanko is offline   Reply With Quote
Old 08-10-2009, 04:02 PM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
#1 Use Georgia Pacific Densarmor fiberglass drywall. No paper to feed mold. Green board is out of date.
#2 Use 5/8 thick drywall to minimize any sag.
#3 Use Georgia Pacific Denshield.
#4 Lowes has some GP densarmor products. You may need to visit a drywall supplier for a full line. Not sure about H-D. I've seen green board at Lowes, see #1.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
Gary in WA (07-26-2010)
Old 08-10-2009, 11:32 PM   #4
Thank for the info guys. This definitely helps!
Old 07-26-2010, 01:23 PM   #5
On the same subject, I am thinking of going with bluboard with plaster veneer, What are the brand names of some bluboards & plaster please? Which combo would be best for a very damp winter environment ?
Laura
Laura J. is offline   Reply With Quote
Old House Rewire finnimus Electrical 15 05-13-2011 11:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
Sub Panel SoxFan Electrical 2 12-02-2008 11:16 AM
Panel Placement In Outbuilding smitty286 Electrical 3 03-31-2008 01:20 PM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 04:49 PM
