Nailing A Joist Hanger To Ledger With Concrete Behind - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree6Likes
  • 1 Post By Nealtw
  • 1 Post By de-nagorg
  • 1 Post By ryansdiydad
  • 3 Post By chandler48
Old 07-21-2018, 09:07 PM   #1
Nailing a joist hanger to ledger with concrete behind
So I've got a 2x10 Ledger attached to a concrete wall. I have a double 2x10 joist that needs to connect to the ledger. I have a joist hanger for this but the installation requirements say to use 16d nails (which are typically 3 1/2" long) to connect to the ledger. How can I do that if the ledger is only 1 1/2" thick? Will the nail go into the concrete? Are there shorter nails?
scottchantry is offline   Reply With Quote
Old 07-21-2018, 10:16 PM   #2
JUSTA MEMBER
Rewards Points: 3,852
Re: Nailing a joist hanger to ledger with concrete behind
Forget the nails in the first place.
Get a box of PAN HEAD wood screws 1 inch long and the diameter of the holes in the hanger.
For that matter never use nails when building anything that is to support another structure.
SCREW IT TO IT.
This prevents nails from pulling out, and they will eventually, even the cement coated sinkers.
Get screws and affix it solid for a lifetime.
ED
de-nagorg is online now   Reply With Quote
Old 07-21-2018, 10:22 PM   #3
SCREW IT TO IT.
ED
What would be the equivalent size screw for a 16d nail?
Old 07-21-2018, 10:30 PM   #4
JUSTA MEMBER
Find that at your BOX store, RIGHT THERE ON THE NUTS/ BOLTS/ NAILS/ SCREWS, aisle.
They have charts placed conveniently, for customer use.
Me I just take the hanger, and try screws until I find the ones that I want, then buy a box, because a box is cheaper per screw than buying a few individual ones.
ED
Old 07-21-2018, 10:38 PM   #5
retired framer
Rewards Points: 15,316
ED
Screws are not approved in every location.
Hanger nails come the right diameter and are 1 1/2" long, they have an Identifier on the head so the inspector can see you have used the right nails. Best to ask an inspector for what screw can be used.
firehawkmph likes this.
Old 07-21-2018, 10:48 PM   #6
JUSTA MEMBER
True, Almost anything is accepted, only in established towns is an inspection needed, in the out of town locations the " sheepherders" get away with all kinds of questionable installations.
So asking your inspector for advice is a good idea.
Even better have a box of doughnuts, and a pot of coffee, waiting, and get the best buddy treatment from the inspector.
ED
Nealtw likes this.
Old 07-21-2018, 11:00 PM   #7
Rewards Points: 1,528
You want these
https://www.fastenersplus.com/10-x-1...yABEgLjavD_BwE
Anywhere that sells the hangers should also sell these screws..
MTN REMODEL LLC likes this.
ryansdiydad is offline   Reply With Quote
Old 07-22-2018, 04:31 AM   #8
JUSTA MEMBER
Originally Posted by ryansdiydad View Post
You want these
That will do great.
ED
Old 07-22-2018, 05:34 AM   #9
Naildriver
chandler48's Avatar
Rewards Points: 3,532
Actually with joist hangers you use two different size nails/screws. 1 1/2" on the flat into the rim and 2 1/2" into the joist an an angle prescribed by the hanger design. Simpson Strongtie has approved hanger screws in their sections in the box stores. They all should be HDG.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Tags
joist hanger , ledger
Ceiling joist ledger board Bgmac Building & Construction 8 03-25-2016 06:20 PM
joist hanger strength question Bonebag Building & Construction 26 05-10-2013 11:05 PM
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 11:19 AM
Joist hanger to sill and ledger? chrishallowell Building & Construction 1 06-14-2010 09:09 PM
