Mud Room Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By 195795
Old 12-07-2018, 05:27 PM   #1
Rewards Points: 42
mud room walls
we have a 10' x 6' closed in mud room-porch. It has double pane windows in it and is weather tight, but not heated, trying to figure out what to use on the walls to finish it, any ideas out there? we live in the n.e
jim111 is offline   Reply With Quote
Old 12-07-2018, 05:39 PM   #2
Rewards Points: 1,272
Re: mud room walls
If you paint it use oil-based paint - stands up much better in non-conditioned areas.
Maybe try something new since you have the chance, e.g., beadboard, shiplap, hardieplank, etc.
cynic and [email protected] like this.
195795 is offline   Reply With Quote
Old 12-07-2018, 08:28 PM   #3
Rewards Points: 118
Re: mud room walls
If you really, really, really want to go rad - Farmtek sells 1/4" white PVC in 4x8 sheets you can put on the walls, stands up real well to manure and other insults.
ChuckTin is offline   Reply With Quote
Old 12-08-2018, 07:01 AM   #4
retired painter
Rewards Points: 1,386
Re: mud room walls
I disagree, a quality latex paint should hold up just as well and is easier to apply and/or recoat. A latex enamel [any sheen] will wear better than a flat latex.
mark sr is online now   Reply With Quote
Old 12-08-2018, 08:52 AM   #5
Rewards Points: 1,328
Re: mud room walls
Sorry not the answer to your question. Mudroom suggests shoes and you want the shoes dry and possibly prevent any water from icing up. I would put some heat there even if you have to use electric and extention cord.
As for the wall material, I don't think it matters, drywall or a plastic panel. But you probably would want drywall first as a solid backer for thin plastic panels. I'd drywall, paint then put a shoe storage against the wall, wide enough to sit.
carpdad is offline   Reply With Quote
Putting color onto white brick or textured walls (need color suggestions!) Eliana Interior Decorating 2 01-18-2012 07:27 PM
Painting room finally Imkindofbigdeal Painting 10 03-16-2011 03:22 PM
One room cold- what pipes are what...help cciampi HVAC 24 02-20-2011 11:44 AM
Removing interior living room walls CLINKER Carpentry 4 02-22-2009 12:54 PM
Hardwood flooring - 3 walls and a sunken living room basledder Flooring 1 12-09-2007 05:34 PM
