Moving A 2x8 True - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-10-2015, 01:37 PM   #1
Rewards Points: 4
Moving a 2x8 true
I need to move a 2x8 that is a support beam for the 2nd floor. I'm turning it into another bedroom and I can't fit any thing up the stairs. I just need to move it to the other side of the beam. The 2 are sistered together but do not run the full length of the opening it is only 38 in wide. I'm also cutting back the floor above it to be even with the new beams. It is only a floor and a rail that can be cut back. Any ideas on what to do to move the 2x8's and replace them with? By the way they are actual 2x8's.
Moving a 2x8 true-img_20150210_132010.jpg   Moving a 2x8 true-img_20150210_131956-1-.jpg   Moving a 2x8 true-img_20150210_131956.jpg
t516 is offline   Reply With Quote
Old 02-10-2015, 03:39 PM   #2
Rewards Points: 1,468
Do you mean that there is ONE two bye eight that goes the full distance, resting on solid support on both ends......PLUS a SECOND two bye eight that goes only part way, sitting on nothing on either end, and is just nailed to the first? And you want to move the short one to the other side of the long one leaving long one untouched? Ron
ront02769 is online now   Reply With Quote
Old 02-10-2015, 04:12 PM   #3
Rewards Points: 4
One is resting on framing and the other is just nailed into it floating. I want to move both of them over just to the other side of the one closest to the door. To give me an extra 4 in.
Old 02-10-2015, 04:59 PM   #4
kwikfishron's Avatar
Rewards Points: 68
If you do that then what's the wall going to sit on?
kwikfishron is online now   Reply With Quote
Old 02-10-2015, 06:32 PM   #5
Rewards Points: 4
The wall is just a railing that is going to be removed.
Tags
architect , carpenter , framing , support beams
moving washing machine, sink and dryer Wyomoming Plumbing 1 10-26-2011 07:45 AM
Moving shower pipes, logistical question (diagram included) mikemcd Plumbing 5 10-24-2011 08:09 AM
Moving Cabin from crawlspace foundation to slab rgood44 Building & Construction 2 08-23-2011 08:37 PM
Moving toilet 12 feet, unsure about venting sputnik62 Plumbing 11 05-10-2011 04:32 PM
laminate moving in one direction nlmedic Flooring 2 03-01-2011 08:38 PM
