Mounted Tv Isn't Straight :-( - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-27-2010, 09:04 PM   #1
Mounted tv isn't straight :-(
Can someone please suggest ideas or what I can do? I'm stuck and bummed and just found this website.
A little background on me, we just bought a house 2 months ago and I'm def a DIY'er, although things just take me 3 times as long as I analyze the issue and then the solution too long.
OK, so back to my issue. I just installed my tv mount on my wall, it came with a self leveler and that was dead center.. PERFECT! I went and put the arms on my tv and then hung it on the mount, it looks to be sloping down to the right. Looks to be about 1- 1.25 inches lower than the left. I have no idea what went wrong BUT I really don't want to take the mount down and drill more holes since again, it was already straight. Has anyone experience this issue before? Is there a simple fix?
The way the mount works is its hung on the wall with two rails, the arms are then bolted onto the tv, and then you just hang the tv onto the mount. Easy Peasy.
I'd love to hear your engineering ideas and still not compromise the security..
Thanks!!!!
scottycam is offline   Reply With Quote
Old 04-27-2010, 10:29 PM   #2
Check it with another level in any case, and use a straightedge rather the TV to amplify any visual misalignment of the rails. It might be an optical illusion.
I suspect the self-leveler was too small for you to measure what's level to the accuracy you need in this case. A 4' level might be better.
Screw holes have a way of walking away from their ideal location.
Without a photo or diagram, let's say it's a 2" rise out of a 25" [TV width] run and the screw holes in the mounting plate are on a 4" square pattern. You then have to raise or lower one end of the mounting plate 4(2/25)= 8/25 of an inch.
Actual errors are usually smaller and can be fixed by wedging a toothpick or larger dowel into a screw hole and then redriving the screw.
Old 04-28-2010, 09:32 AM   #3
holes on tv may be mis drilled
The older I get the better I was
Old 04-28-2010, 09:59 AM   #4
the Musigician
DangerMouse's Avatar
I was thinking almost the same thing, but I'd be more inclined to think it was the arm mounted to one hole at one end, and a different height hole on the other on the TV.
I'd check the 'arm to TV' mount first to be sure the correct/matching holes were used.
DM
Old 04-28-2010, 12:33 PM   #5
Only me...
So I took the tv off today to cross my Ts and dot my I's again.. So, I think I know what the issue is, the top right bolt that holds the mount to the stud broke. So, when the tv is up there, the right side sags a bit. I discovered this when I went to unbolt it and lo and behold, I was able to unscrew it with my hand. What came out was a 1 inch bolt head and smooth body.
I DON'T know what to do next.. Bolt Extractor? Do those even work?
Again, open to ALL ideas..
Thanks!!
Also, the broken part is below the surface.
Old 04-28-2010, 12:55 PM   #6
The bolt is drilled through the wall, into the stud and broke off below the surface. What's the best way of extracting? I need to reuse that hole and that stud in that exact location.
I've seen bolt extractors but what is the tried and true method since this is my first time dealing with this.
Thanks all!
Old 04-28-2010, 01:41 PM   #7
. . .broke off below the surface.
Besides EZ outs, you could chip away a 1/8" or 1/4" deep crater around the screw [?. It's a bolt if it takes a nut] and grab the exposed shaft with Vicegrips and loosen it.
If they slip, grind flats on the shaft and try again.
Or you could use an abrasive cutting disk to grind a 1/16" wide slot in the end of the shaft and the wood, and then use a narrow blade screwdriver to unscrew it.
Old 04-28-2010, 01:44 PM   #8
waterman1971's Avatar
Rewards Points: 156
Weld a nut onto the broken bolt and remove.
waterman1971 is offline   Reply With Quote
Old 04-28-2010, 06:22 PM   #9
kwikfishron's Avatar
Rewards Points: 448
What are you doing?
Why does it have to be the “exact” location?
If you can get it out, the “exact” bolt or lag it might not work again.
Is it a bolt (nuts and washers) or a lag?
kwikfishron is offline   Reply With Quote
Old 04-28-2010, 06:29 PM   #10
Super Moderator
joed's Avatar
Rewards Points: 31,940
What kind of wall? Concrete? wood? plaster? steel?
How big of bolt? Why did it break? If it broke because it wouldn't come out then drilling it and starting over is the only way.
Old 04-28-2010, 06:46 PM   #11
Threads merged on same issue
I'd move the whole thing up 1/2"-1"
Old 04-28-2010, 08:41 PM   #12
Old School
Willie T's Avatar
This is the best and easiest solution. And buy better bolts next time.
Willie T
Old 04-28-2010, 11:52 PM   #13
Rewards Points: 426
Could you not drill another hole through the mount only say an inch down.
Then drill a pilot hole into the stud = to the minor diameter of another lag screw.
Sounds like ya got Chinese fasteners with that Chinese wall mount.
Go to a hardware store vs a box store to get an American made fastener.
The alternative is to move the whole bracket up or down and re drill all holes
as was suggested , don't know if this will expose any of the other holes.
High Gear is offline   Reply With Quote
Old 05-01-2010, 12:20 PM   #14
I got a call from VA to install a wall-mount for a TV.
From this thread it sounds like I should fasten the mount to the TV first and check that all the lines that should be parallel actually are.
Probably the studs will not be in the right place so I'll make a plate wide enough to reach the studs that goes between the metal mount and the wall [customer to stain or paint & supply mount]. Oversize holes with fender washers will give me some latitude for adjustment. If I remember correctly that wall is covered with panelling.
Perfectly straight line Casey Flooring 13 04-05-2011 10:18 PM
Repacing HP condenser with straight cool. bama7x57 HVAC 0 07-26-2009 01:32 PM
How to get a straight line for pavers kingcire Landscaping & Lawn Care 3 07-22-2009 09:15 PM
Removing ceiling mounted cabinets medimaging5047 Remodeling 3 07-16-2009 03:30 PM
Rigid Metal Straight Threads rjordan392 Electrical 2 06-24-2007 11:42 AM
