Moisture Behind Walls. - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-13-2009, 04:58 PM   #16
Originally Posted by itsreallyconc View Post
ck for wtr tracks on the 2x4 studs,,, could be a leak from the roo,,, after the mason finishish'd repointing, did he apply any silicone siloxane to the outside wall ? ? ? btw, this sounds as if its a landlord problem ! ! !
Yes, I have removed some drywall and the furring strips have water marks on them .. as well as some spotty black mold/mildew .. and are damp.
Yes, the mason applied chem-chrete (I think it is called) to all walls after the tuckpointing.
I wish it were a landlord problem.. it is a condo building, we all own our units.
jbennett66 is offline   Reply With Quote
Old 08-13-2009, 06:18 PM   #17
Rewards Points: 3,614
yes, you all own your own units,, HOWEVER, your ownership stops at interior walls,,, the association owns the exterior IF your corp docs are anything like ours,,, here at home, we own it ALL - house, land, AND any repair problems,,, condo rules're different in my experience.
Old 08-13-2009, 10:04 PM   #18
long island, NY
I agree with itsreallyconc... I bet it's a homeowner's association problem. Usually they're in charge of parking lot issues, roof and wall issues (when multiple units share the same roof/wall). If you have units below and/or above you who share the same exterior wall, it's probably covered .
diy'er on LI is offline   Reply With Quote
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 08:17 AM
I'm concerned about the moisture build up on the bathroom walls -Any advice? JayBird General DIY Discussions 15 04-07-2009 10:25 AM
Heavy moisture accumulation on walls when showering mwehnes Remodeling 11 10-09-2008 08:32 AM
Moisture on walls chrisr Building & Construction 1 01-20-2008 09:37 AM
