Microhood Over Gas Range - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-11-2009, 06:44 PM   #1
Question
Microhood over gas range
I've done a complete kitchen remodel and am installing appliances with the last one being the new gas range, having switched from electric. The installation instructions call for a minimum 30 inches between stove top and venthood. I have a microhood instead at the standard height above stove of 17 inches. Will this take the heat or am I going to have a micro-meltdown or risk setting my house on fire?
glennintexas is offline   Reply With Quote
Old 06-11-2009, 07:05 PM   #2
Are you sure they don't want 30" from the stove to the bottom of the cabinet?
jerryh3 is offline   Reply With Quote
Old 06-11-2009, 07:08 PM   #3
The instructions say "30 inches to the vent hood." That sounds really high and implies a microhood won't work as you wouldn't be able to use the microhood if the bottom was at 66 inches.
Does anyone have experience with using a microhood over a gas range with only 17 inches between?
Old 06-11-2009, 08:43 PM   #4
Rewards Points: 162
I think mine is about 18" over the range and I don't have any issues. On our unit, the exhaust fan will automatically kick on if it gets to hot - ie about 30 minutes into the self clean cycle on the oven. It's been going 4+ years with no issue.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 06-12-2009, 05:26 AM   #5
Thanks for the feedback. We will be careful but nice to know this works in service elsewhere.
Gas Range cookiemom1970 Plumbing 1 11-14-2008 04:58 PM
Cabinet Crown Molding and Hood Range? gate1way2 Carpentry 3 10-15-2008 11:13 PM
Same Circuit: Range Hood, DW, and GD? atty_toconnor Electrical 4 04-08-2008 04:43 PM
3 prong range? laduehelp Electrical 39 03-11-2008 01:33 PM
