Metal Roof Vapor Barrier Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-14-2015, 10:49 PM   #1
Rewards Points: 101
Metal roof vapor barrier question
Hello all, I'm getting ready to start the roof of my pole building. I'm planning on a stapled down vapor barrier on top of my 2x6 purlins before laying down the metal roof. I know I should leave a couple inch gap on the sheet metal at the ridge under my ridge cap. My question is should I cut the vapor barrier at the ridge the length of the shop for ventilation or just roll it up and over the peak? Thanks, 1
1dumbquestion is offline   Reply With Quote
Old 09-15-2015, 03:21 AM   #2
Rewards Points: 144
There are inside foam closure that are vented and create a ridge vent .I generally use bubble foil over the purlins leaving it shy of the ridge and then use the vented foam closures with a vented soffit.
mako1 is offline   Reply With Quote
Question about metal roof on shed and drip edge genEus Roofing/Siding 8 09-30-2012 10:27 AM
Replacing shingled roof with metal roof myminpins Roofing/Siding 3 06-26-2011 10:43 AM
Metal roof vs asphalt shingle roof Bob_T Roofing/Siding 1 06-20-2009 06:51 PM
How to vent eaves if no overhang, metal roof, Texas? pj99 Roofing/Siding 7 06-04-2009 03:58 AM
5V crimp metal roof underlayment question ugabulldog Roofing/Siding 1 06-21-2008 01:22 AM
