MDF For A Bartop - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-16-2010, 09:45 PM   #1
Is MDF strong enough for a bartop?
Hello.. I'm building a bar in the kitchen, and I'm curious if 2 sheets of 3/4 MDF board glued together would be strong enough to support a marble tile top.... I had read on one of these sites to glue 2 pieces of 1 1/2" ply, or 4 pieces of 3/4" together for the bartop, but I'd like to keep the cost down where possible...
Also, should I take any extra precautions against water damage, ie spills and such?
Thanks for the feedback!
fanggod is offline   Reply With Quote
Old 03-17-2010, 06:04 AM   #2
MDF is not structural, and will barely support itself. I would stick with plywood, 1-3/4 sheet is fine.
Old 03-17-2010, 05:15 PM   #3
Rewards Points: 3,622
we bld conc c-tops & 1 method's to o'lay 2 pcs of 3/4" ply glu'd AND screw'd
its more important you have the weight support'd well by posts/cabinets !
Bar top CORNUCOPIA Carpentry 5 07-29-2009 03:10 PM
Fasten glass bartop to granite counter? WoodyD Kitchen & Bath Remodeling 4 06-30-2009 01:21 PM
Kitchen remodel question (granite bar top) ASAP! daveincincy Remodeling 13 06-06-2007 02:24 PM
