Max Sized Hole In Rim Joist - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-26-2010, 08:13 PM   #1
Max sized hole in rim joist
Ok, so I am trying to figure out what the maximum sized hole allowable is in a rim joist.
I would like to put two holes (relatively close to one another), both for 4" vents, a bathroom exhaust fan and a dryer vent. The rim joist is 2x12 and the location for the vents is more or less above a door and below a door. Also, there will be a deck ledger attached to the rim joist and the vents would have to go through the ledger board as well. The wall involved is load bearing.
Here is a drawing of what's going on...
And here is an idea of what I'd like to do...
And now for the questions...
So, is this permissible by code?
How big of a hole can I bore in the rim joist?
Is it OK for the vents to go through deck ledger board?
If there is a problem with the size of the hole in the rim joist, can I sister it or install a metal plate to compensate?
Any other thoughts?
stubits is offline   Reply With Quote
Old 04-26-2010, 08:48 PM   #2
Registered User
Rewards Points: 526
3' from any openings into house- doors, windows, supply air ducting, etc.: http://docs.google.com/viewer?a=v&q=...up65cYgFwMvULw
Be safe, Gary
Old 04-26-2010, 09:08 PM   #3
You're fine, just keep the holes tight and try to get them as close to the center of the board as possible. Also try to maximize the distance between the two holes.
You could add some blocking near the holes that run vertically between the floors, and attach them directly to the existing 2x12. This would provide extra support, but may not be necessary.
Houston_Bldr is offline   Reply With Quote
Old 04-27-2010, 04:29 AM   #4
Gary- Wow, that is great and important info. Thanks for saving me the hassle with the permitting office. I would imagine a boarded up/closed up window doesn't count, right?
Also, the 3' rule only seems to apply to a dryer vent, what about a bathroom vent? Or a kitchen exhaust? I realize it might be best practice NOT to have them close to a door/window but can it be done?
And if it can, do you agree with HoustonBlg about going through the rim joist of a load bearing wall as well as a deck ledger? If so, do you have a code reference or other reference? Thanks!!
Thanks for saving me on this one and Houston, thanks a ton for your input.
Old 04-27-2010, 08:03 PM   #5
I have vented through rim joists without a problem.
However, cutting the ledger board would worry me!
The rim joist is supported for its whole length by the sill plate, whereas the ledger board is just supported by its fasteners only!
Would it be possible to support the ledger with another ledger, underneath?
Old 04-27-2010, 08:49 PM   #6
Registered User
Rewards Points: 526
If there is a point load (window jack and king stud) directly above the hole, add a 2x4,?, to the top 1/2 for carrying the load to the sides of the rim joist. Add extra fasteners to each side of the ledger at the hole treating them as ends. No code, just common sense.
http://pdfdatabase.com/code-check-hvac.html
Be safe, Gary
Old 04-28-2010, 06:55 AM   #7
kwikfishron's Avatar
Rewards Points: 846
Vents go through Rims and Ledgers all the time.
kwikfishron is offline   Reply With Quote
Old 04-30-2010, 05:55 AM   #8
Just thinking, I I have a neighbor who I believe put in one vent with a y splitter and a damper so the air cannot flow backwards to the second device, for his bathroom fans. I don't know if code allows this, especially if a dryer is involved but there could be an option for you worth researching.
Chemist1961 is offline   Reply With Quote
Need to drill hole through rim joist for venting creamaster Building & Construction 7 04-02-2012 10:35 AM
one rotted deck joist to replace, need advice dougq Building & Construction 10 07-07-2009 02:18 PM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 10:28 AM
Allowed to run more than one romex cable through a single hole in a joist? J187 Electrical 7 08-17-2007 08:46 AM
Cutting/drilling hole in joist - How big? curls00 Carpentry 3 07-20-2007 09:56 PM
