Masonry - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-08-2009, 09:54 PM   #1
Masonry
Im looking to do some repair work on my house. I need to do some repointing here and there ( nothing major) and I need to determine what kind of mortar they used. Any help would be greatly appreciated
rick32 is offline   Reply With Quote
Old 06-09-2009, 06:24 AM   #2
Matching mortar for esthetics is not a simple job, but if esthetics is not the main issue, any mortar mix will do the job. For proper pointing, the joint needs to be ground out 3 times the width of the joint (1/2" joint requires 1 1/2" deep), and it needs to be cleaned out(air works good).
Old 06-09-2009, 04:35 PM   #3
Rewards Points: 95
Is it an old house? If the original mortar is a lime mortar you will need to use a lime mortar. The mortar used today and sold at most stores can do some major damage to your house if that is the case. There are labs that can tell you exactly what the mix is on your house. Give them a sample and they will analyze it for you. The mix might not match 100% when new. But it will weather over some time and match very well.
NJ Brickie is offline   Reply With Quote
What type of metal to flash chimney and masonry wall? Max1119 Roofing/Siding 6 05-03-2008 05:58 AM
Cheaper masonry alternatives to brick? Jemo Building & Construction 9 05-18-2007 12:31 PM
Sealing above steel lintel in masonry building? mkchicago Building & Construction 1 02-28-2007 07:23 PM
How to mount cables on masonry wall without conduits? dave.murphy Electrical 5 01-24-2007 04:19 PM
