Making Walkout Basement (Existing House) - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree2Likes
Old 03-03-2018, 04:07 PM   #16
Rewards Points: 1,098
Re: Making Walkout Basement (Existing House)
Originally Posted by tsaunde3 View Post
Marson what do you mean "cut back existing floor joist so joist hang off header"? Your LVL recommendation is spot on what I was thinking. I was planning on putting it under the sill plate. Isn't this what I should do? I was planning on anchoring the studs to the cut bock with Tapcon concrete screws and drill them into the areas with a full block of concrete where just the masonry in between blocks was cut. Or should I some how fill the blocks with concrete?
So is the door going into the wall that has the sheet rock leaning on it? If so, those joists need to be supported, correct? Or am I looking at your photo wrong. I was guessing that you didnt have enough room for a header under the floor joists, in which case you can cut the joists and put them into joist hangars attached to your beam.
Marson is offline   Reply With Quote
Old 03-03-2018, 04:53 PM   #17
Rewards Points: 12
OH I see. Well from concrete slab to bottom of floor joist in the basement its 93 inches. A patio door that is 80 inches plus 1 inch or 1 1/2 inches for rough opening. That leaves about 12 inches. If I put it under sill plate then I have enough room for a 9 1/2 inch header. Right? Directly under floor joist gives me a 12 inch header. I never thought about removing rim and cutting joist back to accommodate a header and hang the joist like you would with a deck. Probably shouldn't do that since I'm planning on fastening the new deck to that area as well (rim of house). Should the door be placed towards the exterior of the cut out or middle, or towards the interior of the framed in opening?
tsaunde3 is offline   Reply With Quote
Old 03-03-2018, 06:14 PM   #18
Framing Contractor
Rewards Points: 76
Not sure what your frost line is there, but wont those existing rear footings be exposed to the cold after you excavate?
sixeightten is offline   Reply With Quote
Old 03-03-2018, 06:29 PM   #19
Super Moderator
joed's Avatar
Rewards Points: 29,538
Are you aware that when you dig out all that dirt your house foundation is now no longer below frost. You will need to dig the exposed house footings down so that it is below the frost line.
Old 03-04-2018, 02:04 PM   #20
Rewards Points: 12
Yes removing dirt exposes more of the foundation. You can not see in pictures but the ground slopes away from other half of house. Meaning half of the house is ground level and the other half with the deck is 3 feet buried. They built the footers the same depth all the way around the house so removing the dirt for a walkout is not going to be detrimental to frost heave damage. Thank you all for your concerns about frost heave but Iím really just curious about headers and studs sizes and suggestions
Build house on existing concrete slab troyman Building & Construction 6 04-21-2014 06:05 PM
Options for new basement Perry401 Building & Construction 8 02-27-2013 10:22 PM
Existing Basement Lights - Finishing Basement bergsj Electrical 6 01-04-2013 03:38 PM
tapping into existing HVAC for basement denemante HVAC 3 10-27-2010 06:12 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 10:55 PM
