Main Structural Support Beam HELP!!! - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-15-2011, 09:13 PM   #31
In the overall shot of the basement I'm sure you noticed the pole laying on the ground? I used that pole with a bottle jack on top and another piece of channel on top of the bottle jack to lift the beam.
Daniel048225 is offline   Reply With Quote
Old 02-15-2011, 09:17 PM   #32
Im about to the point where I just want to rip up the hardwood floor and then the subfloor just to get a better look but I know that I would be crazy to do that without exhausting every effort.
Old 02-15-2011, 09:55 PM   #33
Rewards Points: 1,182
I'm still thinking floor... beyond cracks, you can look for it not being flat by laying a board across it and seeing if it touches the floor along the entire length. Particularly, look around the outer posts where you're suspecting sag. If the floor is flat, then see if the columns measure shorter.
WillK is offline   Reply With Quote
Old 02-16-2011, 09:42 PM   #34
Rewards Points: 5,348
The basement has an open ceilling, all you need to do is remove the insulation and look up to see the subfloor. What are you going to see from the top, you can't see from the bottom.
Post a picture of the floor issue over the beam so we can see what's happening.
Ron
Old 02-17-2011, 12:35 AM   #35
Contractor - Renovations
fungku's Avatar
did you check floor to see if it was flat before installing hardwood?
fungku is offline   Reply With Quote
notched & drilled beam = structural issue or not quadred General DIY Discussions 5 09-01-2010 12:05 PM
Cracks in main support beam aikidoka Building & Construction 8 10-12-2009 02:25 PM
How do I reinforce 3story main support beam markelly2008 Building & Construction 2 01-25-2009 10:45 AM
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 09:46 PM
Temporary support for replacement of basement beam Mikedks Remodeling 8 09-14-2006 07:36 PM
