Mahogany Decking Buckling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-27-2010, 04:20 PM   #1
I recently rebuilt my front stairs about 8 months ago and used mahogany decking for stairs and decking. Just recently it started buckling. I sealed the deck when first installed with a quality sealer. I've read from a blog that you should seal all sides before installing, but then I think you can't keep sealing underneath after installation. I've also heard about end grain sealant to prevent buckling.
Doe anyone have experience with this and know how to fix the problem so it might unbuckle and prevent it from happening again?
Thanks.
Red Truck is offline   Reply With Quote
Trex decking LL1 General DIY Discussions 56 09-30-2011 09:55 PM
ribbed steel decking chaos232 Building & Construction 3 06-16-2010 05:15 AM
Trex Decking over Treated Decking retired2pa General DIY Discussions 6 12-15-2009 06:16 PM
installing plywood or backer board over decking gwags Building & Construction 6 04-02-2009 04:55 AM
Decking Michael Avram Building & Construction 2 05-26-2008 07:24 PM
