Looking For A Little Advice - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-23-2016, 11:00 PM   #1
Rewards Points: 6
looking for a little advice
I am in the process of building this patio this is my first framing project I am wondering the best way to handle the corner. I wish the soffit of the old and new roof where the same height but with the beams they are not.
fatboyracing is offline   Reply With Quote
Old 07-24-2016, 01:28 AM   #2
Rewards Points: 254
Re: looking for a little advice
The valley rafters must be inline with patio rafters. Now the roof ply will sit flat on the rafters meeting up with existing roof. String up the imaginary line. Now you see what you have to fill for the roof part. The valley has to be straight, but you will have sort of little wall above the facia.
The patio facia will be a step above the house facia. You need to flash the area with one piece sheet metal, overlapping the drip edge to catch the rain directly into the gutter.
carpdad is online now   Reply With Quote
Old 07-24-2016, 03:34 PM   #3
Rewards Points: 1,036
You will basically be doing the same thing you would do on a dormer.
this first pic is to show how the fascia will run into the roof but i would do the over build differently from what is shown.
this picture is closer to method you will most likely want to use for your over build.
this is the best example the only difference is you will just run your fascia board into the existing roof plane like in the first picture.
this is what the finished product looks like in this situation
Mingledtrash is offline   Reply With Quote
Advice is not always correct! Docwhitley Plumbing 9 02-14-2011 10:12 PM
Chain link fence install advice ponch37300 Landscaping & Lawn Care 1 11-10-2010 07:08 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
looking for Serious advice and Help on Insulation bfan781 Building & Construction 6 05-19-2010 12:02 PM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 12:51 PM
