Load Bearing Wall Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-27-2016, 12:11 PM   #1
Rewards Points: 463
Load bearing wall question
We have been discussing making a pony wall from our kitchen to living room, but right now its a full wall. Our home was built in 1981 and the roof is built with trusses. The wall we want to remove runs perpendicular to the trusses and the wall we want to remove runs parallel with the floor joists.
Since the wall runs parallel with the floor joists it is making me think that this IS NOT a load bearing wall, since the base of the wall could just be sitting on just the 3/4" sub floor?
Can some others chime in on this?
cincinnati guy is offline   Reply With Quote
Old 08-27-2016, 10:06 PM   #2
Msradell's Avatar
Rewards Points: 862
Re: Load bearing wall question
You have two things going for you. The fact that you have trusses normally indicates that interior walls are not loadbearing. The fact that the wall runs parallel to floor joists is also another good indicator. However without actually looking at the situation it's almost impossible for anybody here to give you a definite answer. Might be worth your time to just have a contractor stop by and take a look at it. As long as it can be determined that the wall is not loadbearing you won't need to involve a structural engineer.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Another Load Bearing wall question calibenz Building & Construction 7 10-14-2015 09:44 PM
Load Bearing Wall Question carter72 Building & Construction 15 11-08-2013 11:40 AM
Load bearing wall load points KCK44 Building & Construction 6 11-05-2012 08:34 PM
Load Bearing Wall Question thedudeabides! Carpentry 5 10-25-2011 06:01 PM
Load Bearing wall or not? Dennis6950 Remodeling 5 02-01-2011 08:34 PM
