Load Bearing Or Not? - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By HotRodx10
Old 05-15-2020, 08:46 AM   #1
Load Bearing or Not?
I want to take the interior wall down between my kitchen and dining room. How can I tell if it's load bearing or not?
Load Bearing or Not?-20200514_120709_1589550300967.jpg   Load Bearing or Not?-resized_20200512_200309_1589550325441.jpeg   Load Bearing or Not?-resized_20200512_200315_1589550357341.jpeg
indysunshyne is offline   Reply With Quote
Old 05-15-2020, 09:00 AM   #2
dj3
Rewards Points: 570
Re: Load Bearing or Not?
What do you have over the ceiling - attic or second floor?
dj3 is offline   Reply With Quote
Old 05-15-2020, 10:11 AM   #3
It's an attic.
Load Bearing or Not?-resized_20200514_141702_1589555475551.jpeg   Load Bearing or Not?-resized_20200514_141724_1589555488948.jpeg
Old 05-15-2020, 10:41 AM   #4
Rewards Points: 730
Walls running parallel to the roof trusses are not load bearing, if the roof trusses run parallel on both sides of the wall.
Walls perpendicular to roof trusses, where there are identical trusses with no wall or beam to support them in other portions of the house, are usually not load bearing, but only someone with the skills to trace the load path (i.e. how does the weight of the roof, snow load, etc. get to the foundation) can determine that for sure.
That said, there's no header beam over the window opening, which is a good indication the wall is not load bearing.
HotRodx10 is offline   Reply With Quote
Old 05-15-2020, 11:14 AM   #5
dj3
Rewards Points: 570
It's hard to see from your attic pictures, but find out if the joists over this room run perpendicular to the wall in question, and/or if there's a 4x beam on top of the wall in question.
Just as mentioned above, the absence of a header over the window suggesting it's not a bearing wall.
Always double check.
Old 05-15-2020, 11:27 AM   #6
retired framer
Rewards Points: 12,974
Originally Posted by indysunshyne View Post
It's an attic.
The first truss in the picture is a gable truss but if the truss is above your wall is the same as the rest, you wall is not bearing.
Best if you move some insulation away from it first from above.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 05-16-2020, 02:30 PM   #7
Here are some more pictures
Load Bearing or Not?-resized_20200515_173803_1589657417007.jpeg   Load Bearing or Not?-20200516_120623_1589657425782.jpg
Old 05-16-2020, 03:36 PM   #8
retired framer
It is holding up the ceiling in the other room.
So how much are you looking at removing. If you leave some of the side wall and add a beam you could remove the front wall.
figure 7-14
Old 05-16-2020, 03:43 PM   #9
Rewards Points: 730
Now that we can see it from the other side, one of those walls likely supports the ceiling joists in the room. The other probably doesn't support much, except a strip of the ceiling between the joist parallel to it and the wall. In other words, you probably can't remove those walls without replacing them with beams and a post at the corner, unless you're taking down the ceiling.
Old 05-16-2020, 03:51 PM   #10
retired framer
Do you think an engineer would let them hang the ceiling off the trusses?
The drywall would be the same so it would just be the weight of the lumber on each truss?
figure 7-14
Old 05-16-2020, 05:32 PM   #11
Rewards Points: 730
Probably, but an engineer would have to look at the structural system as a whole to say for sure. Those appear to be scissor trusses, which can sometimes be fairly sensitive to unbalanced loads.
Nealtw likes this.
Old 05-16-2020, 05:39 PM   #12
retired framer
They are likely more out of balance now with drywall that are 75 pounds per 8 ft sheet.
figure 7-14
Old 05-16-2020, 06:00 PM   #13
Rewards Points: 730
Maybe, but without looking at what's carrying the weight and how it's supported now, it's impossible to say whether the load is unbalanced now or whether it would be after removing the walls. Presumably, there are short studs that connect the ceiling joists to the trusses in some fashion, so that there is something to attach the drywall to in that 2 or 3 feet above the ceiling. How sturdy those connections are, and how they affect the trusses, are anybody's guess at this point.
Nealtw likes this.
Old 05-16-2020, 06:59 PM   #14
Thank you all very much. You have confirmed my initial thoughts. I have contacted an engineer to have them take a look. I'll let you know what is determined. Thanks again!
