Load Bearing Joining At Brick Wall. Studs Where? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-06-2015, 04:12 PM   #1
Rewards Points: 2
Load bearing joining at brick wall. Studs where?
Hi guys, I've been searching around for something similar to my situation.
I currently want to remove a wall that is load bearing and replace with a LVL beam. The load on this wall is currently two old dropped ceiling each about 10' to the wall. The joists overlap at the wall. The ceiling is not a massive amount of weight compared to structural parts of the floor and ceilings.
The wall i want to remove goes from the exterior brick wall to a wall that is structurally load bearing. If I put in a load bearing beam then I will need to have a king stud and a couple jack studs on both sides. However the frame work on the brick side looks to be what they call balloon frame. I don't have anything for the king and jack to sit on directly. There is a beam below the hardwood floor that looks solid but I don't know if that is okay to do. I'm trying to figure out a way to secure the studs to that wall properly. I have a couple of images to include here. The header beam will be a flush, so it won't be seen in the end.
Please let me know what you thoughts might be. Should I put it on that plate I see below the floor and also screw the king stud to the brick wall?
corypa is offline   Reply With Quote
Old 02-06-2015, 05:03 PM   #2
Civil Engineer
Rewards Points: 5,246
You have interesting, old style framing. Unfortunately it is impossible to determine from the photos the condition of the supports, or the real geometry of the project. You need to determine the load on the proposed beam, which is normally determined by looking at code for unit loading, but this may not be appropriate in your case.
You mentioned that you were planning to use an LVL, so perhaps you had the LVL sized by the lumberyard supplying it? In that case, you may be able to bring them scaled drawings of the project, and they can suggest methods of support. You also need to discuss the project with your building inspector. The geometry is unusual enough that the building inspector may want your beam and supports designed by an engineer or architect. It is essentially impossible for someone on an internet chat forum, who has never visited your house, to offer reliable design suggestions for such a unique project.
Old 02-07-2015, 08:16 AM   #3
Rewards Points: 7,463
I've been DIY for almost 40 years and there is no way I would consider that without a field visit from a certified structural engineer. The Internet is not the place to get any other form of advice for a project of that magnitude.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is online now   Reply With Quote
60" Sliding Door Installation in Load Bearing Exterior Wall kirbz Building & Construction 8 05-09-2013 05:17 PM
cutting 2 adjacent studs in load bearing wall txbiker Building & Construction 1 02-18-2013 10:50 PM
Removing part of a load bearing wall *with pics* shane2943 Remodeling 7 09-29-2012 10:31 PM
how to tell if a brick wall is load bearing eskowitz Building & Construction 10 08-01-2010 11:00 PM
Load Bearing Wall Issue? iggy913 Building & Construction 1 07-28-2010 07:45 PM
