Load Bearing Beams - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Nealtw
Old 07-03-2018, 10:43 AM   #1
Rewards Points: 32
Load bearing beams
Would like to convert two 8wx7h garage doors to one 18w8h. In order for this to be done there are two load bearing beams which need replacement or reinforcement.
First beam is over the garage doors. I am being told the span is over 20ft so two 1 3/4 beams will not be strong enough. The wall will need to be made wider from 4 inches to 6 inches to accommodate the wider beam.
In the center of the garage is a support which has the back half of the second floor on it which needs to come out. All the floor beams toward the garage doors are parallel to the support beam. Everything toward the back of the home are perpendicular. So, all the floor beams toward the back end, resting on this support. Should this beam be replaced? Or can another one be run parallel right next to it?
After speaking with a few different contractors all giving different opinions on how they are going to do this. I have heard steel, better header add support next to it with metal post in the walls. Prices are all over the place. One company said the architect is $1500 for the drawings and $4500 for the work. Can anyone please offer me some insight to help get me through this project.
Thank you.
Load bearing beams-img_20180703_092819-1-.jpg   Load bearing beams-img_20180703_094628.jpg
Turbo1002 is offline   Reply With Quote
Old 07-03-2018, 12:30 PM   #2
retired framer
Rewards Points: 6,098
Re: Load bearing beams
Yes, You hire the engineer have him draw up what needs to be done. then you get quotes from contractors. Then you are not comparing apples and lemons.
HDS likes this.
Nealtw is offline   Reply With Quote
beams load bearing lycc825 Building & Construction 3 06-01-2013 01:21 PM
meter/main combo to load center grounds and bonding? ronsquery Electrical 2 03-16-2013 06:29 AM
Finding Load Bearing Walls Dane Hitchins Building & Construction 15 05-14-2011 11:09 AM
Can't tell what to do with this wall, load bearing?? fox_forma Building & Construction 22 09-26-2009 06:31 PM
Load Bearing beams? GSaunders02 Building & Construction 16 08-23-2009 07:07 PM
