Load Bearing Beam Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-10-2016, 11:50 AM   #1
Rewards Points: 4
load bearing beam question
I am working on a house at our farm and years ago about 50 to be exact a porch was closed in and turned into a room. The outside wall is buckling now the top is kicking out and the bottom is pulling inward also the bottom beam along the front side of the house is twisting. Does there need to be a load bearing beam on the outside wall of the enclosed porch? The original load bearing beam is 7 feet from the outside wall and the roof is ends on that outside wall.
jameso is offline   Reply With Quote
Old 04-10-2016, 12:47 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 30,556
Re: load bearing beam question
Only an onsite inspection by an engineer can tell you for sure. Pictures might help us guide you.
Old 04-10-2016, 01:22 PM   #3
Rewards Points: 4
I will be headed out there in a couple hours and take some thanks for the quick response
Adding (framing) windows to non load bearing wall question schmaltzy Building & Construction 7 04-13-2015 10:39 PM
Load Bearing removal: hidden beam or exposed? jclee Building & Construction 0 12-04-2012 10:20 AM
Support load bearing beam jhnimh Building & Construction 3 01-19-2012 11:25 PM
Removing bearing wall and putting up a beam Sardinia Building & Construction 2 02-21-2011 07:11 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
