Is This Load Bearing - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By 123pugsy
Old 05-07-2017, 12:10 PM   #1
Rewards Points: 8
Is this load bearing
Hello,
I'm starting to reno my kitchen and was looking at removing the wall between the rooms for the whole open concept look.
My question is when I started to remove the ceiling I hit a part framed in 2x6 and was concerned that it was load bearing. It's right under a beam that all the joist connect to but the wall was put up after the ceiling so does that mean I can remove it?.
amateurfoot is offline   Reply With Quote
Old 05-07-2017, 12:20 PM   #2
Rewards Points: 8
Originally Posted by amateurfoot View Post
Hello,
just adding pics
Is this load bearing-20170507_111453_1494173805103.jpg   Is this load bearing-20170507_111426_1494173919459.jpg
Old 05-07-2017, 10:08 PM   #3
Rewards Points: 1,470
Re: Is this load bearing
Not likely to get an unqualified yes.....but if it was really load bearing it would have been at least a double on edge. Ron
ront02769 is offline   Reply With Quote
Old 05-07-2017, 10:21 PM   #4
Msradell's Avatar
Rewards Points: 912
Can you post some pictures of what the rafters look like above the ceiling? That will give us a better idea what's going on there.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 05-08-2017, 06:04 AM   #5
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,442
95% not. But watch out, that 5% will get you.
There would probably be a header continuing off the end of the wall if it was.
And that sure isn't a beam above it.
What exactly is that piece above the wall?
Windows on Wash likes this.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is online now   Reply With Quote
Old 05-08-2017, 05:37 PM   #6
Rewards Points: 8
[QUOTE=123pugsy;4230201]95% not. But watch out, that 5% will get you.
What exactly is that piece above the wall?[/QUOTE
The "beam" that runs across is 2 2by4's with 2 half inch pieces between with the metal edge to hold the ceiling panels in.
Old 05-08-2017, 06:16 PM   #7
Rewards Points: 8
Hopefully these are better pics
Is this load bearing-1494281563577-1666696269_1494281601228.jpg   Is this load bearing-1494281670164-280857725_1494281694103.jpg
Identifying Load Bearing Posts Reader1 Remodeling 3 06-10-2016 09:47 AM
Window in a load bearing wall diychat09 Remodeling 4 03-08-2016 09:27 PM
Floor Joist Replacement for Load Bearing Wall - Balloon Construction EliseA Building & Construction 1 10-26-2015 09:20 AM
Load bearing post Removal Beaumeri Building & Construction 8 03-04-2015 06:54 PM
Load bearing or partition thoughts? Cutiger26 Building & Construction 0 04-20-2014 04:15 PM
