Lintel Above Shed Doors Too Short? - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By RustyRealtor
Old 01-23-2019, 09:09 AM   #1
RustyRealtor's Avatar
Rewards Points: 751
Hello Again,
Replacing the roof and doors on a little shed. The r.o. is 40" wide for the doors. The existing door frame is steel and is very rotten on the bottom, so will have to be replaced. I plan to replace the steel frame with wood.
It appears, though, that the lintel above the door does not extend past the door rough opening, so that when I remove the steel door frame, the lintel might fall. If you look closely, you can see that the lintels for the windows on the rear wall extend past the opening and I would expect the door to be the same, but no.
Am I correct to be concerned?
Will the lintel sit there until I get new wooden jack studs in place?
Apologies for the rotated photos - seems to happen every time.
The second photo is merely for your viewing pleasure. The beams on top of the steel posts, in the second photo, are 4.5" thick, by 15" tall and 26' long and appear to be one piece.
Thanks For Your Help,
Russell
Lintel Above Shed Doors Too Short?-img_0015.jpg   Lintel Above Shed Doors Too Short?-img_0018.jpg
RustyRealtor is offline   Reply With Quote
Old 01-23-2019, 09:15 AM   #2
Mystriss's Avatar
Rewards Points: 3,756
Re: Lintel Above Shed Doors Too Short?
It kind of looks like the lentil has already failed - looks like there are fractures on both top corners (the one looks like it might have been patched on my screen.)
Personally, I'd brace it while working on replacement. Kind of a PITA to work around, but it's better than having the whole thing collapse while working on it.
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is offline   Reply With Quote
Old 01-24-2019, 08:39 AM   #3
Naildriver
chandler48's Avatar
Rewards Points: 1,034
Lintel was too short from the beginning. Do you plan on a narrower door unit?
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 01-24-2019, 08:47 AM   #4
retired framer
Rewards Points: 1,544
Put 2x4 jack studs inside before you remove the door then put another set out side so you have 7" of jack studs when done. Or just cut it on both sides and replace it with a wood header.
Nealtw is offline   Reply With Quote
Old 01-24-2019, 01:16 PM   #5
Rewards Points: 751
Thanks for the replies.
chandler48, I was going to use a 36" door, but my jack studs would only be 1" thick. A 32" pre hung door will allow for a 2 jack studs on each side of the 40" opening - I guess that's what I'll do and use a wide casing. The opening is only 80" tall, which is another reason to remove the faulty lintel and replace it with wood, as Nealtw suggests.
And the new wooden header will be attached only to the jack studs and the sill plate which will sit atop it?
Thanks,
Russell
Old 01-24-2019, 01:55 PM   #6
retired framer
You only need one jack so you can do a 37" header and a king on each side and you have a 32" door.
Old 01-24-2019, 02:26 PM   #7
Rewards Points: 751
Okay, that's what I'll do - one king and one jack.
Thanks, Neal
Nealtw likes this.
Old 01-25-2019, 04:11 PM   #8
Concrete & Masonry
Rewards Points: 422
It looks like a cast-in-place lintel to me, meaning they laid the block on each side first, and the formed and poured the concrete lintel second. There certainly should be rebar in the bottom of the lintel, tied into the adjacent top course of block.
From what I gather though, you're probably still better off getting rid of the concrete lintel and replacing it with a wood header.
jomama45 is offline   Reply With Quote
Shed doors Solidify Windows and Doors 7 08-02-2016 05:03 PM
Conduit questions in shed wiring TheCowGod Electrical 28 03-18-2012 02:42 PM
Zoning issue with planned shed Ler0y Jenkins General DIY Discussions 15 02-01-2012 01:41 PM
Interior door swelling? jdeters79 Remodeling 9 08-15-2009 11:51 AM
