Lighten Color Of Concrete Patch - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-08-2008, 03:32 PM
Lighten color of concrete patch
Over the weekend I filled a small crack (1/2 inch crack 2 feet long) in my front porch with premixed mortar (the kind in a caulking tube). I know I should have thought about this earlier, but the mortar dried a much darker color than the rest of the front porch. Is there anyway to lighten the mortar? Thanks for the help. DB
dbracco is offline
Old 09-09-2008, 02:26 PM
if its a working crack, just wait a bit & the repair material'll probably crumble & pop out from the movement of the porch due to thermal contraction & expansion,,, unless you realize what type of crk it is, how can you repair it properly ???
other'n that, just wait til the patch gets dirty,,, objectively, you'll never be able to hide it UNLESS you overlay the whole porch,,, i couldn't either, btw
yes.itsconcrete is offline
Old 09-09-2008, 05:06 PM
Im guessing you used a latex type morter caulking(the kind quickcrete sales at homedepot). It was something you shot with a caulking gun right? im a little confused when you said "with premixed mortar (the kind in a caulking tube). " im going to aswer assuming you used caulking which is the right choice (not mortar mix). no matter what you use, you will be able to notice the repair. what i have done before is use the dust i make from grinding the crack out and after caulking the crack sprinkle the dust over the caulking so that it sticks on the surface of the caulking.
KC Brick Layer is offline
Old 09-09-2008, 05:57 PM
we used a couple tubes of that 'stuff' last week on a new strip mall per the supt's instructions incl the 'dusting' trick,,, i stand by my earler post, kc.
caulk is a poor choice of mtl for cracksealing,,, sealants are always preferable w/2sided adhesion, NOT 3.
yesitsconcrete is offline
Old 09-09-2008, 11:05 PM
where would the 3 way bond be? its a crack. caulking would seal from one edge of the crack to the other side of the crack. as long as the ratio is 1 to 2 on the depth to width you would be fine. if the crack was to wide than just use closed cell backerod.
Old 09-10-2008, 05:11 AM
if it were done w/caulk, just fill it,,, to give proper adhesion to the sealant, we'd use either bond-breaker tape or closed-cell backer rod,,, VERY rarely use dever foam anymore,,, but i can't see the crack from my house
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 09:21 AM
How to level small patch of cured concrete? RDS General DIY Discussions 11 06-05-2008 01:41 PM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
Concrete patch for lally column footing? AllGoNoShow Building & Construction 6 10-21-2006 09:16 PM
