Lean Too - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree4Likes
Old 01-21-2019, 05:24 PM   #1
hunter
Rewards Points: 26
lean too
New guy here and first post. Hope you guys can help me out. As soon as I learn how to upload pictures to this thread I will do so. I heave a pole barn that I wish to add a lean to. I need approximately 12' height under the lean too for parking. The bottom of the rafter is at 11' so adding a lean too under the rafter and attached to the side of the barn is a no-go. I need help understanding how I can maybe and hopefully add a lean too to the barn roof. As soon as possible I will upload pictures. Hopefully this is the best forum for my post. If i'm wrong someone please direct me to proper forum. Thanks
hunter100 is offline   Reply With Quote
Old 01-21-2019, 05:39 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 23,496
Re: lean too
If I am understanding correct you want to do something like this.
Nealtw likes this.
Old 01-21-2019, 05:49 PM   #3
hunter
Rewards Points: 26
Re: lean too
Attachment 547427
That was fast. I did just take pictures and am working on this now. An yes--this is what i would like to do. Thanks
Old 01-21-2019, 05:55 PM   #4
retired framer
Rewards Points: 18,482
Re: lean too
So what do you need to know.
Nealtw is offline   Reply With Quote
Old 01-21-2019, 05:59 PM   #5
hunter
Rewards Points: 26
Re: lean too
Well--right now i am trying to download pictures so i can show you guys what i have. Where do i go to download pics? I don't see anything under UserCP.
Old 01-21-2019, 06:05 PM   #6
retired framer
Re: lean too
When you are typing look down a little and see go advanced and then find
Manage attachments
The Following User Says Thank You to Nealtw For This Useful Post:
hunter100 (01-21-2019)
Old 01-21-2019, 06:07 PM   #7
hunter
Rewards Points: 26
Re: lean too
OK--I have my pics here but not sure if they will be included in my reply.
Old 01-21-2019, 06:13 PM   #8
hunter
Rewards Points: 26
Re: lean too
Got the pics uploaded. I have a dirt wall to the left of my barn. It measures approx. 15' between barn and dirt wall. As i said, the rafter is too low to be adding to as it measures just about 11' off the ground. I need advice as to how to add to the existing roof and maybe extend roof out to above dirt wall. This property is all hill and water runoff is a big problem. Then there is the snow load as well. All said and done--i need lots of advice and specifics if you guys can help.
Old 01-21-2019, 06:18 PM   #9
Rewards Points: 1,272
Re: lean too
You say you need about 12' so just dig out a foot of ground there and ur good to go - easy
195795 is offline   Reply With Quote
Old 01-21-2019, 06:23 PM   #10
retired framer
Re: lean too
You have some good choices,
1. It looks like you have solid blocking at the heel of the trusses so you could nail or bolt a ledger to that Just lower than the other roof.
2. cut out beside the truss to slide rafter in and nail it to the truss, remove the OSB inside so you could put a heel block under it. Then the roof would continue at the same pitch.
3 go above for a lower pitch and put a soul plate right above the wall.
4. If you want to go high like Joe's picture you would build the wall higher to support most of the weight instead of over loading the trusses.
Old 01-21-2019, 06:29 PM   #11
hunter
Rewards Points: 26
Re: lean too
I'm down below the walls at this point. Thanks
Old 01-21-2019, 06:31 PM   #12
retired framer
Re: lean too
Your new supports have to be below frost depth, so if you go on top of that ridge and say your depth is 3 ft you would have to go over 3 more feet too.
Old 01-21-2019, 06:32 PM   #13
hunter
Rewards Points: 26
Re: lean too
I will have to study the terminology of the process you mentioned and take this advice from there. Any pictures to guide me would be nice also. Thanks much.
Old 01-21-2019, 06:37 PM   #14
hunter
Rewards Points: 26
Re: lean too
Ok--I understand what you mean. Guess the rafters would be pretty long. Would you use 2x6 or so? Thanks
Old 01-21-2019, 06:38 PM   #15
retired framer
Re: lean too
In this picture, they have put the rafters on top of rafters and we can see beams inside that can easily handle the weight. You don't want to do that with trusses with out paying for an engineers report and instructions, so you add to the wall straight up under the new rafters,
Drop gable stick build with lean to roof crecore Building & Construction 19 01-17-2016 03:02 PM
Lean to shed Fantom Building & Construction 1 07-07-2014 05:20 PM
want to build lean to shed, need opinions fenders Building & Construction 25 05-21-2012 09:39 PM
Lean To Shed against side of house mappler Building & Construction 3 02-18-2012 05:57 PM
connecting a lean to foof gamecock 2012 Building & Construction 2 01-13-2012 11:07 PM
